96 ZJ UC Sway bar link size [PIC] - JeepForum.com
post #1 of 5 Old 06-03-2013, 02:52 PM Thread Starter
picflight
Both sides broke off, got a couple from an online retailer and they are different sized. Obviously one of them is not correct.
Does the UpCountry suspension have a different length?
What is the correct length for my stock Jeep?
1996 Jeep ZJ Laredo V8 5.2L UpCountry.
picflight is offline
post #2 of 5 Old 06-03-2013, 07:06 PM
tucsonzj
http://www.quadratec.com/products/56004_0018.htm
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #3 of 5 Old 06-03-2013, 07:08 PM
tucsonzj
you have 10 degrees of angle to play with in the front sway bar. Should be between 5 and 15 from center of the tube out to the middle of the connection of the sway bar link. I don't believe they used different lengths as it was only 1" difference. They did use different ones for the 93-95 and 96-98.
tucsonzj is offline
post #4 of 5 Old 06-03-2013, 10:07 PM
Oldfrog
2007 WK
I have UC on my 97 and dont recall the links being different, but I've slept since then.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
post #5 of 5 Old 06-04-2013, 03:17 AM
tucsonzj
tucsonzj is offline
