96 zj trans problems - JeepForum.com
post #1 of 13 Old 07-04-2016, 09:19 AM Thread Starter
jeepin1981
I had a 96 grand cherokee that I sold to a guy yesterday, 4.0l, auto trans. I didn't drive the jeep much but it always ran good and shifted good. He came and test drove it and everything was fine, he purchased it and drove it an hour and 20 minutes away. Said it ran perfect. He parked it at home, came out an hour later to drive it and said it takes about 20 seconds to go into gear and when it does, it slips. Fluid level is good and clean, I changed it a week ago. Any idea on what it could be?
jeepin1981 is offline
post #2 of 13 Old 07-04-2016, 09:21 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
If it was fine before you changed the fluid, I'd guess it might be low.
HighLonesome is offline
post #3 of 13 Old 07-04-2016, 09:34 AM Thread Starter
jeepin1981
I asked him to check the fluid, he said the level was perfect......
post #4 of 13 Old 07-04-2016, 09:37 AM
MrRoundel
Did he check it while it was warmed up, idling, in neutral, and on a level surface?
It probably doesn't really make this kind of a rapid difference, but did you use ATF+4 fluid?
MrRoundel is offline
post #5 of 13 Old 07-04-2016, 09:54 AM
dellis
2005 WK
What transmission fluid did you use when you did the change?
1998 ZJ, 4.0 // 2005 WK Limited, 4.7 // 2008 KK 3.7
dellis is offline
post #6 of 13 Old 07-04-2016, 10:03 AM Thread Starter
jeepin1981
ATF+4. not sure how he checked the fluid, guess I should make sure he did it right.
post #7 of 13 Old 07-04-2016, 10:18 AM
MrRoundel
Yeah, many just think they can check it like engine-oil.
post #8 of 13 Old 07-04-2016, 10:21 AM
dellis
2005 WK
There may be some ideas in this thread:
http://www.jeepforum.com/forum/f13/j...luded-1212867/
His problem was likely low fluid level. And, if you don't get any other ideas out of this thread, it is at least some fun reading.
dellis is offline
post #9 of 13 Old 07-04-2016, 10:30 AM Thread Starter
jeepin1981
He just text back, said it was in park when he checked it, told him it had to be in neutral, level ground, warmed up, and running. He said he went out this morning and it was running fine but started acting up again when it warmed up....
post #10 of 13 Old 07-04-2016, 01:21 PM Thread Starter
jeepin1981
He said he just checked the fluid the way that I told him to and said it is good
post #11 of 13 Old 07-04-2016, 07:23 PM
HighLonesome
buyer beware, especially on ZJs
post #12 of 13 Old 07-04-2016, 07:41 PM
dellis
2005 WK
Yeah, I was thinking the same thing. This is a perfect example of why car Bill of Sales state "as is, without warranty".
dellis is offline
post #13 of 13 Old 07-09-2016, 11:59 PM
Pugulis
What does he want you to do? He test drove it and it drove fine. He drove it home and it drove fine. Now it has problems? How do you know he didn't screw something up and isn't telling you. I sold a car to someone once and the day after he bought it, it did a neutral drop to try and do a burnout. Well he wrecked the transmission. Now he told me exactly what happened. How do you know this guy didn't do something similar and is now trying to get his money back. Just be straight with him. Tell him it was working fine and he test drove it and there's nothing more you can do.
[_][]☺[][][]☺[][_] RIP to my 96' Grand Cherokee Laredo 344,700 miles and welcome to my new 2001 WJ
Pugulis is offline
