96 ZJ TCM Reset? Overdrive not working? - JeepForum.com
post #1 of 6 Old 12-11-2012, 05:41 PM Thread Starter
1999blacksvt
Hey everyone. I had recently changed out my radiator, trans filter, and replaced the fluid. Right after I noticed crappy shifting and slipping so I put more fluid in it and she was g2g. On a 2 hour trip my trans over temp starting flashing and my overdrive went out.
As of now overdrive still does not work. I noticed that my trans cooler hose was twisted so I untwisted it and reset the battery. It still won't go into overdrive. What are my options? Can I try resetting the TCM or does resetting the battery do this?
What else could it be? Overdrive fried?
1999blacksvt is offline
post #2 of 6 Old 12-13-2012, 06:47 PM Thread Starter
1999blacksvt
Anyone?
post #3 of 6 Old 12-13-2012, 07:04 PM
ZeeJay1997
You dont have a TCM. The PCM does that on >95
Never heard of a trans over temp on a ZJ, but I'm a 2wd guy
Is the green LED illuminated on the OD button?
ZeeJay1997 is offline
post #4 of 6 Old 12-13-2012, 07:10 PM Thread Starter
1999blacksvt
Yes it is upon startup. Letting the battery reset helps, but eventually the light comes on upon start up and only goes off if I press it off. It shifts fine but O/D never kicks in. I've heard when these go into safe mode during over heating the O/D kicks off, however I read to reset the TCM. But if the PCM controls it, that means unhooking the battery would reset it correct?
post #5 of 6 Old 12-13-2012, 07:38 PM
ZeeJay1997
No, The control module determines transmission shift points based on input signals from the transmission thermistor, transmission output shaft speed sensor, crankshaft position sensor, vehicle speed sensor, and throttle position sensor.
Cycle the ignition key On - Off - On - Off – On within 5 seconds and see if the odometer shows any codes.
post #6 of 6 Old 12-19-2012, 05:08 PM Thread Starter
1999blacksvt
Pulled a 12 and 55 codes. So those seem to be normal. What next?
