96 zj positive battery cable - JeepForum.com
post #1 of 9 Old 07-02-2013, 11:22 PM Thread Starter
iceman10058
okay so i noticed that my battery cables were coroded the other day, so i figure that i would save myself some trouble later on and get some new cables. went to my local parts store and they tell me that they cannot tell me the length needed and i cannot fond anything online anywhere so can someone help me out?
iceman10058 is offline
post #2 of 9 Old 07-02-2013, 11:42 PM
a70eliminator
Have to just break out the ol yo yo and get an estimate from the existing ones.
a70eliminator is offline
post #3 of 9 Old 07-03-2013, 07:33 PM Thread Starter
iceman10058
damn. i was afraid of that
post #4 of 9 Old 07-03-2013, 08:38 PM
a70eliminator
Well, if anything spank on a couple new terminals.
post #5 of 9 Old 07-03-2013, 10:01 PM
Uniblurb
Uniblurb's Avatar
Unfortunately the OE battery cables for your 96 4.0 are part of a wiring harness to alternator, starter, etc.. Did a search for it (#9 in diagram, 5601778) and $100, discontinued online, so maybe only the dealer would have it at even a higher price. It may be time to make up some new ones.
BTW, be sure and check the PDC connection from the positive cable to make sure it's not corroded too. And can't stress how important it is to clean your 3 ground connections on the block. There's 1 on the oil dip stick tube bracket bolt and 2 on the coil studs by the passenger side motor mount. A bad ground (oil, rust, corrosion) on one of the coil studs took out 2 of my PCM's along with a couple crank sensors. This is the only ground for the PCM which in-turn grounds all the sensors and it's a vicious circle. Good luck.
96 4.0 ZJ Laredo, 2004 4.7L WJ Limited, 93 4.0 XJ (spare), 96 4.0 XJ (son's)
Uniblurb is online now
post #6 of 9 Old 07-03-2013, 11:02 PM
5-90
5-90's Avatar
1988 XJ Cherokee
Chances are good that ALL of the cables at the battery are corroded, and the corrosion will go back under the jacket (the factor won't seal their cables very well.)
Check your PM box, I'm about to send you some info.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #7 of 9 Old 07-04-2013, 05:43 AM
AVR2
Just thinking ahead to an issue that may become relevant to me, how feasible is it to make up your own battery wiring harnesses? Is it a major PITA? I've just checked the availability of the 1993 4.0L battery wiring, and up to 7-16-92 is now discontinued, but 7-17-92 onwards is still coming up as available - at an eye-watering $217 (and that's after online discount). My ZJ is an "early build" 1992 model, so I guess that means that the OEM harness is no longer available.
AVR2 is offline
post #8 of 9 Old 07-04-2013, 11:38 AM
Uniblurb
Uniblurb's Avatar
Wow AVR2 that is a high priced battery harness! I too would like to make up my own cables but don't need all the wiring that comes with them. Wish I could find the thread but about the best battery cable set-up I've seen is where a guy used the military style battery terminals like below. Then he increased the cable gauge while buying all his parts (HD coated lugs/eyelets you solder on with solder pellets in connector bottom using a torch, etc.) at a marine supply store. Then he used thick shrink wrap to cover the solder joints and connector ends. Know some use welder cable but that stuff's pricey too.
http://www.grainger.com/Grainger/QUI...MP6?Pid=search
Note the above is for a 5 pk of the larger positive side and know they sell them singularly.
post #9 of 9 Old 07-04-2013, 12:43 PM
chalkboard
I did some reading here when I was having stalling issues.
http://custombatterycables.com/appli...kee_cables.htm
2001 WJ 4.7/73k "Old Bones"
1997 ZJ 4.0/154k Sold
chalkboard is offline
