96 ZJ - No Blower Motor - JeepForum.com
post #1 of 2 Old 04-09-2013, 04:01 PM Thread Starter
BrandonLong
Hello Everyone,
Was trying to see if I could get some hindsight on how the system works.
Currently I have no blower motor, tested for positive had it and replaced motor, still a no go.
Went in for some further diag and I don't have a ground to the motor? It also appears I have a constant +12v on the positive line. So is this a switched ground system? Where would you look to start on fixing it. Checked all fuses/relays.
Have the manual controls
-Brandon
-Brandon
BrandonLong is offline
post #2 of 2 Old 04-09-2013, 05:03 PM
KoreaZJ
1994 ZJ
Check the connectors on the front of the heater box for pin damage from overheating.
There are usually visual "burny marks and meltyness" (author: ratmonkey)
Looks something like this
Some cut the connectors out and splice all the wires together.
Or just bypass the connector with damaged wires spliced together.
KoreaZJ is offline
