96 ZJ~leaking transmission line - JeepForum.com
post #1 of 7 Old 07-10-2007, 01:28 PM Thread Starter
Hogweed
hello all,
i recently replaced the radiator w/ an all metal one. everything was ok until the lower trans cooling line fell off the radiator fitting the other day after about 300 miles of driving over about a ten day period. i guess i didn't have it on all the way and it came loose. i have it back on now but it is leaking. i went to the dealer to see if they had a parts list for that connector thinking i'm missing an o-ring or something. they are not able to pull up a detailed diagram and there are no parts listed short of buying the whole line back to the tranny for $140!!
there seems to be a plastic sleeve that fits into the end of the hose as well as the plastic clip that snaps past the shoulder on the radiator outlet.
does anyone know why it would leak, if i'm missing a part or parts or if there are any less costly fixes for this?
thanks.
gh
So many cars, so little time
Hogweed is offline
post #2 of 7 Old 07-10-2007, 07:21 PM Thread Starter
Hogweed
this board moves too fast! bump
Hogweed is offline
post #3 of 7 Old 07-10-2007, 08:16 PM
chadgtr
Cut off the hose by the crimp and hose clamp it in the elbow that comes out of the radiator. The elbow should have a little shoulder to it that the stupid plastic clip attatches to. This should take care of the leak and it costs about $1.00.
1993 ZJ 4.0 I6
3.5" Tuff Country Suspension Lift
31x10.50 BFG A/T KO
Crager Soft 8's
On Board Air
Chad-made Quick Disco's
chadgtr is offline
post #4 of 7 Old 07-10-2007, 09:25 PM Thread Starter
Hogweed
you are a genius! i'm so focuse on fixing it "right"! your fix will be be better than the idiotic set up thats on there now. thanks!
gh
Hogweed is offline
post #5 of 7 Old 10-01-2009, 08:25 AM
_AdriaN_
Ok, this post is a little old, but anyone care to explain a bit better ?
What kind of connector does it take to fit the piece that comes out of the bottom of the radiator ?
Right now I am using a worm clamp to hold it on, although it isn't doing a good job.
Pics would be great....
96 ZJ 4.0
04 TJ 4.0
87 Rx7 TII
_AdriaN_ is offline
post #6 of 7 Old 10-01-2009, 04:35 PM
indianajeep
indianajeep's Avatar
2005 WK
I did the fix and took the pics - check it out-
http://www.jeepforum.com/forum/f13/t...-96-zj-746300/
indianajeep is offline
post #7 of 7 Old 10-01-2009, 07:43 PM
_AdriaN_
Thank you ...
Although I have already fixed it. I talked it over with a friend and he helped me out.
Again, thanks a lot in your effort.
96 ZJ 4.0
04 TJ 4.0
87 Rx7 TII
_AdriaN_ is offline
trans cooler line leaking at radiator morrison308 ZJ Grand Cherokee Forum 18 07-07-2014 08:53 PM
94 ZJ transmission line leaking bad trans line clip? hvywt77 ZJ Grand Cherokee Forum 4 09-14-2010 10:16 PM
Transmission Cooler Line leaking... 1badjk WK Grand Cherokee & XK Commander Forum 3 10-25-2009 07:32 PM
transmission cooling line leaking causing overheating? lma1973 ZJ Grand Cherokee Forum 5 09-28-2007 07:26 AM
Leaking Condensate Line in Pass Compartment cdyer77 ZJ Grand Cherokee Forum 2 09-15-2006 07:24 AM
