96 ZJ Just stops running. - Page 3 - JeepForum.com
post #31 of 39 Old 09-12-2013, 08:31 PM
ZeeJay1997
no, it shouldnt die. you are eliminating it as a cause.
i believe something is shorting out to sensor ground and resetting the pcm.
ZeeJay1997 is offline
post #32 of 39 Old 09-13-2013, 12:43 AM
Speedymcracer01
Everytime a sensor shorts out like mine did it causes the pcm the lose power everytime the sensor arches from bad wiring or grounds out its resetting the pcm erasing codes at the same time your vehicle stalls. I tested all my pcm circuits by hand with a curcuit tester before i realized it wasn't a bad pcm. It was faulty sensor wires, check into your sensors a little more check those hard to get to wires in-between your sensors and the pcm
Speedymcracer01 is offline
post #33 of 39 Old 09-13-2013, 04:39 AM
newfieZJ
I think you are correct . I would suspect a break between the CPS and PCM
newfieZJ is offline
post #34 of 39 Old 09-13-2013, 05:01 AM
ZeeJay1997
from what you posted below, here 's a scenario that fits. the PCM first detects an open and pops a code. then it shorts out and blows the PCMs mind.
this would be an indication that something is mangled. tip of crank sensor maybe. O2 wires?
post #35 of 39 Old 09-13-2013, 09:03 PM Thread Starter
MeWJWifeZJ
Replaced both Oxygen sensors with Mopar parts (again, under warranty) and inspected the wiring and found no cut, scoring or exposed wiring. Started the truck and it died immediately, once i got it to stay running I unplugged the cam sensor and it immediately died, when i plugged it back in, i could hear the ASD relay click off. I also noticed that with the cam sensor unplugged, the CEL was on with the key when it wasnt constantly before. Time for a new cam sensor?
Praise to a Child is like Sunlight to Flowers
Traded away the WJ to get a commuter
We finally got another Jeep after 5 years without. Too bad it's ALL stock.
MeWJWifeZJ is offline
post #36 of 39 Old 09-14-2013, 12:08 AM
Speedymcracer01
Well it sounds like a very good idea to replace it
post #37 of 39 Old 09-14-2013, 07:21 AM
ZeeJay1997
Going dead when you remove the CAM sensor from the circuit does not indicate a bad CAM sensor. A bad CAM sensor would be indicated by the problem going away when you disconnect it, causing default fuel timing to be used by the PCM.
The battery has been disconnected and the PCM is learning its fuel strategies is probably why the engine goes dead when you disconnect it. That's only speculation.
Also could be due do some other problem you haven't found yet, so the cam disconnect was of no help.
When you disconnect sensors, you get codes. Normal operation.
post #38 of 39 Old 09-14-2013, 10:50 AM
ZeeJay1997
Do you mean the lamp check at 'key on' was inconsistent before disconnecting the cam sensor? If this is the case, yes, the cam sensor may be culprit.
post #39 of 39 Old 04-04-2014, 10:36 AM Thread Starter
MeWJWifeZJ
Sorry for the delay in responding to this but it did turn out to be the Cam sensor. Replaced it with an aftermarket in a reman distributor to get the Jeep going and it runs and doesnt die often but once its' warmed up it loses power like its not getting fuel when I accelerate up a hill or if I go WOT. I picked up a factory cam sensor and I am going to swap that in tonight with new cap, rotor, wires and plugs. Hope it finally starts to run right.
