Quantcast 96 ZJ GC Loud clunk from rear when turning - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 96 ZJ GC Loud clunk from rear when turning
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGR8TOPS Introduces the Exogate HD Tire CarrierThe Original 3/8" Ruffstuff Diff Cover!
Old 04-17-2009, 08:58 AM   #1
davehope80
Hi Guys,
I have a 96 ZJ and when i turn a corner at slow speed i get a clunk coming from the rear and it feels as if i have my hand brake on or my brakes are hanging on. I have checked the brakes and they are fine, sliders are nice and free and the piston in the callipers mive nice and free, i have also checked the oil in my rear axel which is a dana 35 got plenty oil in it it is looking a little brown so it my need a change. I was just wondering if any of you guys have had the same problem and may be able to give me some advice on this.
Thanks.
PS iam new to the forum and from the uk.
davehope80 is offline   Reply With Quote
Old 04-17-2009, 09:05 AM   #2
fransdemers
Looks like your visco's are gone to the dogs...
Try to make '8' figures at slow speed in a parking lot somewhere at idle speed...
If your jeep hungs up or makes funny noises or has trouble doing this, you won first prize.
I put all my money in beer, then afterwards I get it out and lick it dry...
fransdemers is offline   Reply With Quote
Old 04-17-2009, 09:18 AM   #3
davehope80
Hi
Thanks for the reply, I know i may be sounding dumb here but what are visco's, and are the easy to replace or do i need a new axel.
Thanks again.
Old 04-17-2009, 09:54 AM   #4
fransdemers
Visco's are Visco coupled gearing devices.
They lock your axle in case of slipping and getting stuck.
During normal drive, they should unlock, and that is what they don't do anymore on old axles...
Then the ride gets bumpy.
Replacing means axle revision and this isn't cheap.
So, go to a parking lot and start making those 8-figures and let us know how it went.
Or hop over the channel and come to Bruges
Old 04-17-2009, 12:12 PM   #5
ZJMAN
I think he's talking about the clutches in the rear diff!!?? I have no idea what Viscos are. Anyway, it sounds like the clutches and plates are binding in the diff. The last time I checked, the repair kit was still available through Mopar and some gear venders. New LSD units are still available through Dana parts suppliers as well.
ZJMAN is offline   Reply With Quote
Old 04-17-2009, 05:21 PM   #6
NEVADAGARY
NEVADAGARY's Avatar
Sounds more like he's talking about the viscuous coupler in the transfer case. If that's bad need a new transfer case.
Gary D.
Old but having fun
Real Americans drive Real American!
NEVADAGARY is offline   Reply With Quote
Old 04-17-2009, 09:04 PM   #7
Daldo
Rear End
dude just drain your rear diff and check your spider and axle gears, chepest thing to check. thats where i would start, also make sure your whole rear end is in the air so you can spin your tires and check the ring and pinion.
I can't see any way that it could be your tc if you hear it in the rear end. And you should check your yoke on the drive shaft side of your rear diff, could be loose and at slow speeds your tc and rear end could be getting confused causing the yoke to bang around. I know it sounds weird but it happens. let me know. Have Fun!
You Break A Dana 30 You Put A Dana 44 In It, You Break A Dana 44 You Put A Dana 60 In It, You Break A Dana 60. Give Up!!
Daldo is offline   Reply With Quote
Old 04-19-2009, 10:44 AM   #8
davehope80
Hi Daldo
Just been out to drain the oil in my diff and it is as thick as hell look's like thick black sludge, not to happy with that as it supposed to have been changed by the last owner be he sold it to me, and also found three bit's of teeth from one of the gears. Not good so iam going to try and see wot it's like with a oil change, also drained the tc oil and that is looking like crap to so going to refill that with fresh oil. And see if i still get the clunk, if i do then it look's like a repair kit of of ebay.
Old 04-19-2009, 11:14 AM   #9
baxy
sounds like 2 problems viscous coupler in the tcase binding and a limited slip problem in the rear
make sure when you change the rear diff oil you put in a friction modifier
the factory trac lok diffs are always broken
baxy is offline   Reply With Quote
Old 04-19-2009, 09:14 PM   #10
Daldo
Originally Posted by davehope80 View Post
Hi Daldo
Alright man you need to take the carier pin out or the carier, 12 PT 6mm socket you'll strip it with anything else, when you take that out you need to remove the axle and spider gears. After you take the gears out you will be able to see your ring and pinion allot beter. Hopefully you will only have to change out the axle and spiders, about 94$ on quadratec. just changing the oil in the diff will do absolutly nothing but waste your time. Needs to be fixed.
Old 05-08-2009, 05:26 AM   #11
davehope80
how hard is it to remove the carier and change the spider gears on this, and also is there any where in the states that ship over the pond to the uk, as iam haveing problems finding any where in the uk that do the parts i need unless i go to the stealership.
thanks gys
Old 05-20-2009, 04:50 PM   #12
fern30
2002 KJ Liberty
www.rockauto.com. bought from them many a time and recieved the stuff quicker than if i went to the dealer myself! Excellent. Ordered once early tuesday, knock on the door thursday.
fern30 is offline   Reply With Quote
Glock Forum
