96 ZJ Front End Rumble - JeepForum.com
post #1 of 4 Old 03-13-2011, 05:44 PM Thread Starter
ovrclkd
I'm the new owner of a 96 ZJ which has a front end rumble. The rumble or vibration is felt through the steering wheel and is lightly audible. It begins around 40 to 45 mph and continues up to 70 (probably more but I haven't gone that fast.) There is no shake to speak of and is less when 4WD is engaged. There is a little play in the u joints at the axles (not much at all) and the shaft from the transfer case to the differential has a bit of play, I can move it about an 1/8 of a turn back and forth.
Another thing I noticed is hard over to left the steering tugs back and forth, almost like a wobble?
Turning to the right does it but not as aggressively.
I am completely new to Jeeps & any type of 4WD so any insight is greatly appreciated.
Regards,
Jay Riling
PS> a buddy said it might be the front axle? I changed the tires so I'm ruling that out.
ovrclkd is offline
post #2 of 4 Old 03-13-2011, 06:41 PM
KingtheZJ
pull out for front axle and see if it goes away. by "u joints at the axles" do you mean halfshafts IN the axle, or the ujoint on the driveshaft at the pinion?
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #3 of 4 Old 03-13-2011, 07:25 PM Thread Starter
ovrclkd
The u joint at the axle that the wheel is on. I apologize for my lack of not knowing what each part is called. I am buying a Haynes manual so I won't be refering to the "whatjamacallit" and "you know that shiney thing" so much in the future.
ovrclkd is offline
post #4 of 4 Old 03-13-2011, 07:30 PM
KingtheZJ
haha no problem. yeah if the hal fshaft (sometimes called axle shaft) u joints are worn that could cause a vibration. also, there is a cv ball in the double cardian (the 2 ujoints right next to eachother) on the dront driveshaft that can cause similar problems.
'88 XJ
Driveline Rumble BilletHorse ZJ Grand Cherokee Forum 1 08-23-2010 03:30 PM
Rumble, vibration in rear end?? Gerald K4NHN ZJ Grand Cherokee Forum 2 12-02-2007 10:40 AM
Rear End Rumble barrowjeep ZJ Grand Cherokee Forum 4 02-20-2007 04:36 PM
Rumble from drivetrain? DTom ZJ Grand Cherokee Forum 2 12-03-2005 05:24 PM
Vibration (Rumble) only under acceleration Deanwa ZJ Grand Cherokee Forum 4 08-24-2004 08:58 PM
