96 ZJ 242 roaring noise in part time upon decel - JeepForum.com
post #1 of 10 Old 01-26-2010, 05:15 PM Thread Starter
indianajeep
indianajeep's Avatar
2016 JK Wrangler
Like the title says - when I put my 242 in part time, it makes a roaring noise upon deceleration. 2 wheel drive is fine - no noises. 4 wheel full time is fine, except every once in a while I get a whirring noise that comes and goes around 50 mph. 4 low seems to be fine, but 4 low is hard to tell just because it's a loud gear anyway.
The axle was just recently swapped in and doesn't have any vibes or noises of its own. The tfr case also made these noises with the old axle (that did have issues of its own - bad pinion and carrier bearings and worn pinion and ring gears).
I'm figuring that the gears that govern 4wd part time are singing their last song, and if that is the case (no pun intended) then, the rest of the TFR case cannot be far behind - anyone with any experience with this issue?
indianajeep is offline
post #2 of 10 Old 01-26-2010, 10:59 PM Thread Starter
indianajeep
2016 JK Wrangler
bump????????
post #3 of 10 Old 01-27-2010, 03:41 PM Thread Starter
indianajeep
2016 JK Wrangler
bump again
post #4 of 10 Old 01-27-2010, 05:23 PM
nick62087
when you hear the roaring in part time, are you on hard pavement?
nick62087 is offline
post #5 of 10 Old 01-27-2010, 07:55 PM Thread Starter
indianajeep
2016 JK Wrangler
Yes. It happens on dry pavement.
post #6 of 10 Old 01-27-2010, 08:12 PM
RhinofiedZJ
Is there snow covering the dry pavement that your driving on in part time? If not you shouldn't be in part time, that might be the problem. Use full time or 2wd.
1995 ZJ 2" BB, 31x10.50/15 KM2's painted stockers, B&M RV shift kit, 18k cooler, Extended Energy sway bar links.
RhinofiedZJ is offline
post #7 of 10 Old 01-27-2010, 08:36 PM
melk
^^^ X2. 2wd or Full time is all you need.
Has the TC fluid been changed recently? Can't hurt. Easy and inexpensive to boot.
melk is offline
post #8 of 10 Old 01-29-2010, 08:20 PM
nick62087
Dont Use Part Time On Dry Pavement!!
post #9 of 10 Old 01-30-2010, 06:52 AM Thread Starter
indianajeep
2016 JK Wrangler
Every once in a while when I shift from 2wd to 4 full time, it will make that same noise while it is in 4 full time - sounds like it might be binding in 4 pt on its way to shifting through to 4 full time.
post #10 of 10 Old 01-30-2010, 01:03 PM
eshew
I was having the same prob but with ft. I now shift the tc to n then back up to ft and haven't had the problem since.
eshew is offline
Whining/Roaring Noise coming from rear driveshaft/diff. asu4x4TA ZJ Grand Cherokee Forum 5 02-21-2011 07:27 PM
Decel Noise from front - Help EVILUTION ZJ Grand Cherokee Forum 8 11-05-2009 09:27 PM
RE: Roaring Noise uncc09meet ZJ Grand Cherokee Forum 2 08-13-2007 02:08 PM
Smoking Diffs? Part Time/Full Time? azcoyote ZJ Grand Cherokee Forum 30 04-01-2007 07:29 PM
96 jgc makes slight roaring noise at 50mph marv ZJ Grand Cherokee Forum 0 07-13-2002 11:32 AM
