96 Wet Floorboard Repair Costs - JeepForum.com
post #1 of 8 Old 06-12-2013, 10:19 AM Thread Starter
Will9119
After 2 years my leaking AC problem has returned. The first time I fixed it I was unable to find a clog in the drain and used caulk over the seal between the unit and the firewall. I assume that the seal is what is causing the problem because I was not able to find a clog. I called the dealer today to schedule the service but they were unable to provide me a solid price estimate. I'm assuming because of the work involved with accessing the seal it will be fairly expensive. My question is, has anyone had this done at the dealer and what does it cost?
Will9119 is offline
post #2 of 8 Old 06-12-2013, 11:19 AM
PolkaPower
You are going to get raped at the dealer for anything you go there for.
PolkaPower is offline
post #3 of 8 Old 06-12-2013, 11:22 AM
4x4andmetal
A lot of people have done this their self with some caulking. I believe there is a thread on here about it.
1996 4.0 Laredo. Weekend warrior
1999 Pontiac Grand prix GTP. Daily driver
1995 318 laredo. Gone
4x4andmetal is offline
post #4 of 8 Old 06-12-2013, 12:25 PM
Dumpy
1972 J-Series Truck
There's a thread showing where to cut inside the wheel well. I did it and found one of those winged seed things blocking the tiny hole. No problems since.
'96 ZJ
'72 Jeep J2000 Pickup
Dumpy is offline
post #5 of 8 Old 06-12-2013, 01:22 PM
ghiotom
You are going to be horrified at what the dealer tells you.
ghiotom is offline
post #6 of 8 Old 06-12-2013, 02:09 PM
eagsc7
1994 ZJ
Tell us what the dealer charges, then come here and do it yourself.
eagsc7 is offline
post #7 of 8 Old 06-12-2013, 06:07 PM
sillygoose
Here you go man. I used a hole saw, caulked the foam stuff from that side, and also put the hose on. My floor seems to be drying up now.
http://www.cherokeeforum.com/f52/ac-...pet-fix-24246/
sillygoose is offline
post #8 of 8 Old 06-13-2013, 06:45 AM Thread Starter
Will9119
Dealer quoted me at least $1200 so instead of going through that I'm going to try the wheel well method today. If it works I will be eternally grateful to you guys.
Will9119 is offline
