96 Transmission HELP - JeepForum.com
post #1 of 9 Old 08-28-2013, 06:31 PM Thread Starter
DevJeep90
Hey guys, 96 ZJ 4.0, having trouble with my tranny. 42RE. 205,000 on it with original tran. I've been searching the forum for a month and reading the FAQs to no avail. Almost positive it's the tranny. 1st. When I'm in drive and accelerating from a stop my transmission jerks or kicks into gear. It will do the same thing when I come to a complete stop I feel and hear a kick or jerk. 2nd. When I first start the jeep it will shift hard into 3rd gear. Doesn't want to shift until I let off the gas a little and it will finally drop in. Only does it the one time when I first start driving. Changed the fluid and filter about a month ago. Any help would be great. Hoping my transmission isn't dying. Thanks
DevJeep90 is offline
post #2 of 9 Old 08-28-2013, 07:33 PM
edpmedic
Did you also adjust the band's when you changed the oil and filter. Checked to make sure the intermediate and low reverse servos are not sticking in the bores? Have you tried it when not in overdrive? How does it shift when you manually shift it? Does it still have the same problem? Chances are with that much mileage it's time for a master rebuild or a rebuilt trans. I'm not sure how the throttle valve linkage works on the RE version. I had the 46RH which had an adjustable throttle valve cable.
Never4get those who gave their lives on 09-11-01 WTC and Pentagon. FDNY-EMS-NYPD-PAPD. Also those who are still dying.
_______________________________________________
"Freedom is never voluntarily given by the oppressor; it must be demanded by the oppressed."
Martin Luther King, Jr.
"Always aim at complete harmony of thought and word and deed. Always aim at purifying your thoughts and everything will be well."
Mahatma Gandhi
Feel the Sunshine on your face
edpmedic is offline
post #3 of 9 Old 08-28-2013, 09:30 PM Thread Starter
DevJeep90
Didn't adjust the bands but it's something that I might have to do. Not at all sure how to check the servos.....have to research that. I'll try it without overdrive tomorrow. My apologies but it shifts into 2nd gear......it's getting out and into 3rd thats hard. Could this be a TV cable issue? Hate to have to rebuild the trans.
post #4 of 9 Old 08-30-2013, 08:01 AM Thread Starter
DevJeep90
Drove it without overdrive and it was no longer jerking when I came to a stop or let off the brakes to start moving again. Once I put overdrive back on it would start doing it again. Anyone heard of this before? Any ideas? Thanks
post #5 of 9 Old 09-03-2013, 05:27 AM
edpmedic
Sorry took so long to get back. I was looking for the online shop manual for the trans. I know if you do a search going back a little more then a year ago. There is a link for the 46re trans. Do a search under edpmedic for transmission or band adjustment and I think the link is there. I only have my phone and it's a PITA trying to find it. I think your problem is related to a solenoid on the valve body, but I'm really not sure.
It's one of those scribd on line documents. Maybe you can search for it that way. Also is your overdrive light flashing. I think that is where the trans codes are read by counting the blinks like the CEL.
Mahatma Gandhi
edpmedic is offline
post #6 of 9 Old 09-03-2013, 07:45 AM
JS97ZJ
Courtesy of Morris 4X4...knowledge base section of their website.
http://www.jeep4x4center.com/jeep-se....swf#toolbar=0
JS97ZJ is offline
post #7 of 9 Old 09-04-2013, 09:50 AM Thread Starter
DevJeep90
Thanks for the info guys. I'm going to try and change the solenoids this weekend and see how that goes. If there's no improvement which I'm guessing there won't be, I'll work on adjusting the bands. I drove it without OD and I could notice a little jerk on start and stops but nothing compared to what it does with OD. My other trans issue -->The hard shifting into 3rd seems to be intermittent. Sometimes it will do it (only once the 1st time it shifts into 3rd) and sometimes it won't do it at all. Might even shift easier into 3rd when i accelerate hard rather than taking it slow. I'm thinking this is unrelated to my other issue and is may be a TV cable issue/adjustment. I'm no expert by anymeans so i could be waaayyyy off.
post #8 of 9 Old 09-04-2013, 09:56 AM
JohnnyZJ
od solenoid. probably got dirty and bunged up.
i'd swap it if you're pulling the pan again. also, put a drain plug in the pan and flush the tranny a few times. there is a lot of fluid in the transmission; it takes about 2-3 times to clean all the old crap out.
07' JKUR rollin on 35s
JohnnyZJ is offline
post #9 of 9 Old 09-04-2013, 11:13 AM Thread Starter
DevJeep90
That sounds good. I'll do that too.
