96 straight six just dies randomely help - JeepForum.com
post #1 of 10 Old 04-22-2013, 08:09 AM Thread Starter
damule
Jeep just dies randomely.after few minutes will restart.I have replaced so far,plugs and plug wires,flywheel position sensor,and dist cap.anyone else have this problem?Is something shutting down the fuel rail?any help is appreciated.
damule is offline
post #2 of 10 Old 04-22-2013, 08:13 AM
ZJNewbi3
I read a lot of guys have trouble with their PCM connection. Have a buddy wiggle and firmly hold the connection while you try turning it over.
ZJNewbi3 is offline
post #3 of 10 Old 04-22-2013, 09:37 AM
JS97ZJ
Read through all of this thread and it's links, your problem is in there somewhere,
http://www.jeepforum.com/forum/f13/1...talls-1407423/
JS97ZJ is offline
post #4 of 10 Old 04-22-2013, 10:28 AM
antknee
I'm having the same problem with my 1993 straight 6
antknee is offline
post #5 of 10 Old 04-22-2013, 05:30 PM
Nick05
1994 XJ Cherokee
check your fuel pump and iac. my wife's 97 was doin this. i cleaned it(torx bolts to get it off) and no problems since. it is common and are easy to do.
Nick05 is offline
post #6 of 10 Old 05-07-2013, 06:42 AM Thread Starter
damule
what do you mean by iac.I have since replaced the distributer as well.still shutting down randomely.
damule is offline
post #7 of 10 Old 05-07-2013, 07:02 AM
kensnelling
IAC= Idle air control motor, a cylindrical shaped device mounted on the side of the throttle body. If you haven't already read the link above on things to do and check I'd suggest doing that before throwing more money at your Jeep.
Ken
kensnelling is offline
post #8 of 10 Old 05-07-2013, 07:46 AM Thread Starter
damule
just scanned the link.will get back after going through the dirty dozen
damule is offline
post #9 of 10 Old 05-08-2013, 03:57 PM
Nick05
1994 XJ Cherokee
the iac is easy and only cost you a can of cleaner(and possibly torx screws if you are like me and drop them)
Nick05 is offline
post #10 of 10 Old 05-08-2013, 04:01 PM Thread Starter
damule
ok after replacing dist. now the engine is missing not shutting down.Have code cam or crank missing is my dist.off a tooth?
damule is offline
