96 Limited electrical problem and stalling - JeepForum.com
post #1 of 2 Old 09-09-2003, 01:57 PM Thread Starter
tweek
I am hoping someone has an idea or solution for my dilema. I have a 96 JGC Ltd 4x4 V8 and my problem is that the vehicle occasionally stalls while driving. This always seems to be precluded by times that I needed constant access (not excessive)to the inside of the vehicle opening and closing doors (camping/ loading up kayaks and gear). These simple events have also lead to draining my battery, which shouldn't be the case with normal use. I know it's not the battery as I have had it tested many times. Does anyone have any idea what could be the problem(s)? Any suggetions would be appreciated.
Thanks
tweek is offline
post #2 of 2 Old 09-15-2003, 09:48 AM
automan25
What kind of battery are you using. Does it have enough amps to run all the lights on the Jeep for extended periods of time? I find it strange that this situation would have anything to do with a drained battery as once the engine is started the power that the vehicle uses comes from the alternator/voltage regulator system. Have you had those checked out?
My vehicle died recently up in the mountains ($150.00 tow). It turned out to be the cam position sensor (located inside the distributor) and the coil. The sensor was about $40 and the coil $25.
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
2004 Grand Cherokee Limited electrical problem...help needed!! Thor7000 WJ Grand Cherokee Forum 6 12-27-2013 12:54 PM
Weird 2000 Limited Edition electrical problem geepondy ZJ Grand Cherokee Forum 3 02-18-2007 12:03 AM
95 Jeep GC Limited 4.0 Stalling And Other Problems Keith1975 ZJ Grand Cherokee Forum 2 11-26-2006 06:39 AM
96 Limited v8 stalling and battery drain Brettr ZJ Grand Cherokee Forum 1 10-30-2006 11:48 AM
Help! 99 Limited, strange electrical problem knobbier ZJ Grand Cherokee Forum 9 06-17-2006 04:37 PM
