96 limited build. - Page 6 - JeepForum.com
post #76 of 505 Old 09-27-2012, 08:24 AM
1991welder
Some new projects to think about like rhino lining your "Console" and a pillers and doing your headliner cheap and easy stuff
1991welder is offline
post #77 of 505 Old 09-27-2012, 08:42 AM Thread Starter
nickpequignot
I actually did plan on that. Just havnt got to that. Thank you. What kind of rhino liner did you use?
nickpequignot is offline
post #78 of 505 Old 09-27-2012, 07:40 PM
1991welder
I had mine sprayed professionally at work we do all kinds of truck accessories including bed liners dont waste your time with the stuff in the can its not good
post #79 of 505 Old 09-27-2012, 07:51 PM Thread Starter
nickpequignot
In the spray can? How's the roll on stuff?
post #80 of 505 Old 09-27-2012, 07:59 PM
DickDickle
I disagree with you, I have applied herculiner to a few beds and once properly prepped they finish great and last. The last truck I rolled out had a sander in it all last winter and you can't even tell.
DickDickle is offline
post #81 of 505 Old 09-27-2012, 08:05 PM
1991welder
Yea there good i have nothing against them i said the stuff in the can "spray can"
post #82 of 505 Old 09-27-2012, 11:11 PM
DickDickle
Misunderstood you when you said don't use the stuff in the can instead of spray can,two different types of applications
post #83 of 505 Old 09-28-2012, 08:25 AM
1991welder
I have my own build thread and a guy on here posted pics where he did his whole ZJ in the roll on stuff
post #84 of 505 Old 10-09-2012, 07:36 AM Thread Starter
nickpequignot
I am thinking about doing monstaliner on the the inside. But if nothing else the console and the pillars when I put those back in
post #85 of 505 Old 10-10-2012, 02:28 PM Thread Starter
nickpequignot
Next Friday I'm getting a dc audio 12 in level 3 sub. Not going to put it in till I get a new amp. Probably going to be audiopipe. Then going to get one more set of speakers and some 1in tweeters for the dash. And when I do my cento console project will be going to put all the stuff in going to have speakers in the center console I. Front and rear. Front door speakers will be on my kenwood amp as well as the front console speakers. Then rear speakers and dash tweets will be on my Jensen amp. Going to have 0 gauge going to it. Probably going to run a second battery inline with the amp power. Going to be a kenitc. Eventually I want to get a 99+ alt as those are 117 amp. And do big 3 upgrade. Would also like to do some aux lighting while the console is still out since it will be easier to run wires. Looks like the bb might get pushed off till next spring.
post #86 of 505 Old 10-12-2012, 11:56 AM Thread Starter
nickpequignot
The sub I'm getting next Friday.
post #87 of 505 Old 10-13-2012, 07:29 PM Thread Starter
nickpequignot
Today I ordered a red led toggle switch with safety cover. As well as a blue with blue safety cover. Blue will be for my low beams, red for the high beams. Going to use fog lights as low beams and driving lights as high beams. Going to replace the head light with theses as we all know zj head lights lack quite a bit. I also ordered a red led for the reverse lights I'm going to put on. So I don't have both relays sending power to the lights at the same time. Going to slowly collect all of the lights and everything for the interior then do all that at one time. Then will start doing the rest of the out side.
post #88 of 505 Old 10-17-2012, 12:04 PM Thread Starter
nickpequignot
Waiting on two more switches to come in. Then will have all the switches I need. Have 100ft of black 14 ga and 100ft of red 14 ga. Need to get two distribution blocks and some relays then I will have everything for the interior other than another set of speakers. A set of tweeters. New sub and another amp
post #89 of 505 Old 10-17-2012, 01:23 PM
360grand
Are you not using any of the factory switches??
360grand is offline
post #90 of 505 Old 10-17-2012, 05:27 PM Thread Starter
nickpequignot
Nope everything is coming out and going to te center console or I'm adding stuff that needs switches. I am doing my own head lights that won't be wired to factory head light wiring. Need to figure out how to do the dimmer switch yet. Just centralizing everything in the center console basically other than hvac controls.
