96 laredo - JeepForum.com
post #1 of 12 Old 06-02-2013, 09:48 PM Thread Starter
96gdck
96 laredo
Lower dash screen saying coolant sensor bad and rear lamp failure. What do they mean?
96gdck is offline
post #2 of 12 Old 06-02-2013, 09:56 PM
jm8881
Basically it means that you didn't use the search button.
The vic is prone to bad connections and weak solder joints. There is a how to on here somewhere that shows you how to fix the coolant sensor problem.
As far as the rear lamp failure I'm not sure but someone is bound to chime in.
jm8881 is offline
post #3 of 12 Old 06-03-2013, 07:02 AM
Dubfire98
yea the bad coolant sensor is almost always the solder joint on the inside of the vic (if your coolant levels are normal). if you take the vic apart there is a pink with black stripe wire, inspect the solder joint for a miniscule crack and repair. As far as the rear lamp failure... Well plainly put... You have a tailight or something similar burnt out. Its usually one of the smaller third brake lights on the top of the hatch. Hope this helps.
Dubfire98 is offline
post #4 of 12 Old 06-03-2013, 08:46 AM Thread Starter
96gdck
That's just it. None of the lights are burnt out but it's saying the failure.
96gdck is offline
post #5 of 12 Old 06-03-2013, 10:56 AM
Dubfire98
hmm... id start by removing the vic and taking it apart and inspecting the solder joints. They are pretty shoddy from factory anyhow.
post #6 of 12 Old 06-03-2013, 08:14 PM
ZeeJay1997
there are three bulbs in the third brake light. if one is out, you get the message.
OP, fill out your jeep info so it shows up
<--- over here
ZeeJay1997 is offline
post #7 of 12 Old 06-03-2013, 08:53 PM
JasonStebbins
<--- over here
Also check the corner bulbs on the tail lights. I didn't even realize I had them until I pulled the lenses out one day to clean everything.
Poop
JasonStebbins is offline
post #8 of 12 Old 06-04-2013, 08:35 AM Thread Starter
96gdck
Where do I fill out my jeep info? The arrow isn't pointing anywhere.
96gdck is offline
post #9 of 12 Old 06-04-2013, 08:52 AM Thread Starter
96gdck
Nevermind I figured it out. I'm on an app on my phone and I had to go to the actual website
96gdck is offline
post #10 of 12 Old 06-04-2013, 07:10 PM Thread Starter
96gdck
Ok so I found out today why the screen is saying rear lamp failure, the tail lights are staying on after the jeep is off and key is out, and the lights are not on. Unhooked the battery and hopeing it resets it, but if not are there any suggestions?
96gdck is offline
post #11 of 12 Old 06-04-2013, 07:14 PM
JasonStebbins
Tail lights or brake lights? If all three of the brake lights are illuminated then replace the brake switch under the brake pedal.
If it's only the tail lights I would guess your headlight switch is bad. The soldering is pretty cheesy on a lot of the ZJ parts.
Poop
post #12 of 12 Old 06-04-2013, 07:31 PM
ZeeJay1997
Just to eliminate it as the cause, open the little cubby hole on the floor behind the spare and disconnect the lamp outage module. Then join the two connectors you took off together, bypassing the module.
if that doesnt work, be doubly dang sure you see three lamps in the high brake light.
