96 jeep grand cherokee Body control module location - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 96 jeep grand cherokee Body control module location
1993-1996 Jeep Grand Cherokee (6 Piece) Headlight, Corner 1997-1999 Jeep Wrangler Stainless Steel Exhaust Manifold &1999-2003 Jeep Grand Cherokee Head Gasket & Bolt Set f
Unread 10-01-2011, 12:58 PM   #1
biggoofy
Im 90% sure my BCM is causing my issues the problem is I cant find it or a picture of one for the life of me anyone have some insight on this?
[CENTER]Zack
96 ZJ HP44 / 9"
90 XJ on 33s
RIP Troy aka BigBlueZJ94
FroBot Fab FTW
[URL="http://www.mallcrawlin.com/forum/showthread.php?22776-Biggoofy-s-96-ZJ-build!-**Building-axles**"]My Build[/URL]
Need quality parts call Andy at Ironman4x4fab!!!!!
[url]http://ironman4x4fab.com/index.html[/url]
[/CENTER]
biggoofy is offline   Reply With Quote Quick reply to this message
Unread 10-01-2011, 01:04 PM   #2
gactech
http://www.wjjeeps.com/ecm_02.jpg
http://www.wjjeeps.com/modules.htm
Sorry about that. Bottom of the page has locations
gactech is offline   Reply With Quote Quick reply to this message
Unread 10-01-2011, 01:31 PM   #3
airwolf9090
Driver side under the dash on the wall..
1996 Jeep ZJ Orvis
airwolf9090 is offline   Reply With Quote Quick reply to this message
Unread 10-01-2011, 01:54 PM   #4
biggoofy
thats on the wj not the ZJ
[CENTER]Zack
96 ZJ HP44 / 9"
90 XJ on 33s
FroBot Fab FTW
[/CENTER]
Unread 10-01-2011, 03:11 PM   #5
zachjf
Needs parts?
PM Kolak or kolak@kolakperformance.com
zachjf is offline   Reply With Quote Quick reply to this message
Unread 10-01-2011, 03:21 PM   #6
biggoofy
Its an arrow pointing to nothing lol. Can someone post a pic of what it looks like please
[CENTER]Zack
96 ZJ HP44 / 9"
90 XJ on 33s
FroBot Fab FTW
[/CENTER]
Unread 10-01-2011, 04:57 PM   #7
zachjf
it should be behind the wiring harness plugs/brackets etc, thats where mine is anyways
Needs parts?
Unread 10-01-2011, 05:01 PM   #8
MeanGreenZJ
It's mounted under the headlight switch, you get to it from under the dash.
kgrhqeokoye33ewwbzzbof22c60dq-_3.jpg   kgrhqeokpwe3t5yrvdnbof218vgeg-_3.jpg   kgrhqiokjoe3s6sndq8bof22liowg-_3.jpg
MeanGreenZJ is offline   Reply With Quote Quick reply to this message
Unread 10-01-2011, 05:10 PM   #9
biggoofy
Thank you so much man!!!!!!!
[CENTER]Zack
96 ZJ HP44 / 9"
90 XJ on 33s
FroBot Fab FTW
[/CENTER]
Unread 05-19-2015, 10:12 AM   #10
Truevil
From what I seen it is plugged into the fuse box on the back. The 1996 fuse box on mine is located on passenger side near the floor under the panel next to the door.
Truevil is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 10:46 AM   #11
Daing_Maing
I have wiring diagrams if you need them. Just PM me...
Here's what I have for a 96 ZJ:
Daing_Maing is offline   Reply With Quote Quick reply to this message
Unread 05-19-2015, 10:52 AM   #12
SAR-Swimmer
Hey gang, he probably solved his problem 4 years ago.
SAR-Swimmer is offline   Reply With Quote Quick reply to this message
