96 Grand Cherokkee power windows, locks and gauges cut in and out. - JeepForum.com
post #1 of 4 Old 07-12-2012, 04:40 PM Thread Starter
nathanstevens
Hey im new here and i have been looking around for a solution to my problem but have yet to find one that works.
here is my issue.
most of the time everything is fine but every so often, at least once a day all of my gauges will die along with the other warning lights and none of my windows will roll down or up. also the power locks will only work on the door i push the lock button on(driver side wont control any others). I have noticed that if i bang on the arm rest on the passenger side door everything will begin to work again, but sometime only for a couple of seconds, other times its good for a day and other times it just does nothing.
I have seen other people posting with problems like this one but no one mentioned that their problem was intermittent.
I have checked all my fuses and i looked at the wiring in the pass door but nothing seems bad i also have tried disconnecting the negative lead to my battery and reconnecting it half an hour later and it still didnt help.
this is a very annoying problem and i hope to find a solution soon as it is now summer and getting very hot out and i dont have the ac working in it either.
nathanstevens is offline
post #2 of 4 Old 07-12-2012, 04:54 PM
Area.3.Fiftyone
Bad or loose connection on the BCM.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #3 of 4 Old 07-12-2012, 05:03 PM Thread Starter
nathanstevens
is there any way i could fix this?
post #4 of 4 Old 07-13-2012, 10:03 AM
Area.3.Fiftyone
Search for BCM or Body Control Module.
Everything you are experiencing is controlled by it.
Check to see if the connector is loose, or it can also have gone bad. Not hard to change, but you must get one from the correct model year.
96 is different from 97-98.
electrical issue , gauges , power door locks , power windows
95 Grand Cherokkee Not Starting RM95jeep ZJ Grand Cherokee Forum 9 02-26-2011 12:24 AM
Power Windows and Locks 06ltd WK Grand Cherokee & XK Commander Forum 1 01-08-2010 03:32 PM
Power Locks and Windows donstylez ZJ Grand Cherokee Forum 0 10-27-2009 04:27 PM
99 WJ Limited Electric issue with locks, windows, gauges, and more...need help superarmen ZJ Grand Cherokee Forum 6 08-21-2008 08:00 PM
Power Locks/Power Windows on Passenger Side ccox ZJ Grand Cherokee Forum 2 07-09-2005 09:46 AM
