96 Grand Cherokee (XJ?): Changing the brakes - JeepForum.com
post #1 of 3 Old 04-07-2007, 06:46 PM Thread Starter
balson
Hi, I would like to learn how to change the brakes, both front and rear in the Cherokee. I'll need to learrn how to do this if I want to keep the jeep for a lot more than the 11 years I've already had it to stop it from bleeding my wallet. Is there something I should buy to help me along? I believe there are the technical manuals that jeep sells for like $1-200 that may help. Is there anything else? What tools will one definately need o get the job done? What tools are optional that will make the job easier? Any gotchas that I should be aware of?
Any advise at all would be appreciated.
Thanks, Jim
balson is offline
post #2 of 3 Old 04-07-2007, 07:27 PM
Vestjam
Welcome....
First off, a 1996 Grand Cherokee is a ZJ.
Brakes are not hard to do as long as you follow some simple rules. One of the first things you'll want to purchase to help yourself is a large C-clamp to help press the caliper piston back into the caliper.
Do a search on this site for 'Brakes'
also, look here: http://www.jeepforum.com/forum/f13/brakes-question-393118/
Check out ebay for 'manuals and literature' under ebay motors/car and truck parts.... A good Factory service manual (FSM) will be invaluable in all of your Jeep endeavors.
[B]2008 Jeep Wrangler X
[B]1997 Jeep Cherokee Country 4.0L/AW4
Vestjam is offline
post #3 of 3 Old 04-07-2007, 07:35 PM
zaq123
zaq123's Avatar
1941 JK Wrangler
It's very easy to DIY, no special tools needed, all metric sockets. Pick up the clamp as Vestjam suggested
When you go to auto store to get your break pads, pick up a Haynes manual, $15
It will give you basic idea about your ZJ + step by step routine maintenance and some repair info
zaq123 is offline
'00 Jeep Grand Cherokee Engine Knocking after changing oil depebush ZJ Grand Cherokee Forum 23 04-09-2009 01:16 AM
any pictures of changing pinion seal of grand cherokee 1999 shahriarrrr ZJ Grand Cherokee Forum 25 03-02-2008 07:41 PM
'95 Grand Cherokee - changing spark plugs jeep95 ZJ Grand Cherokee Forum 17 06-12-2006 04:34 PM
Changing a headlight on an 04 Grand Cherokee?? boyandhisjeep WJ Grand Cherokee Forum 3 02-05-2004 07:05 PM
Changing speakers in 98 Grand Cherokee Laredo sgtrahanlsu ZJ Grand Cherokee Forum 3 12-03-2002 02:50 PM
