96 Grand Cherokee Transmission lines - JeepForum.com
post #1 of 9 Old 11-10-2005, 06:19 PM Thread Starter
dieth
2008 WK
Coming out of the radiator is a hard line. There is a flexible line that attaches to that with a removable fitting. This fitting leaked before and Jeep made me buy the whole line back to the transmission. Now it's leaking again and the only replacement is $80 line. All that's probably bad is an o ring. Anybody experience this and have a fix?
dieth is offline
post #2 of 9 Old 11-10-2005, 09:03 PM
wizjeep97
I have the same problem with the bottom transmission line going into the radiator. Was quoted $88.00 by the stealership. I have looked all over to find it as an aftermarket part with no luck! Mine is not leaking too much so it will stay like that!!!
wizjeep97 is offline
post #3 of 9 Old 11-11-2005, 09:47 PM Thread Starter
dieth
2008 WK
I was quoted about the same $88 price. Funny thing is there is a detachable rubber hose on the hard line going back to the trans but you can't just buy that. The front of this rubber hose ( about a foot long) has that fitting that keeps leaking. There's no excuse for Chrysler not to make this short piece avail, choosing instead to screw the customer for a whole transmission line. < end of rant>
Even though I like the Grand Cherokee, stuff like this ticks me off. I may just replace all the lines with braided stainless hose.
Rick
dieth is offline
post #4 of 9 Old 11-12-2005, 10:13 AM
sgarlic
I would send an email to bulkpart.com and see if they have a fitting you could use for that.
sgarlic is offline
post #5 of 9 Old 11-12-2005, 11:21 AM
PIGH8TER
2012 WK
yeah I hear ya w/ the tranny lines. mine had a small crack and all of the tranny fluid eventually leaked out of it. not good at all.
anyways, I had to replace that whole line also. costed me about the same price that everyone else here is saying. it's too bad that you cant replace just the rubber hose and not having to replace the whole line
2012 Jeep Grand Cherokee Overland, 5.7 Hemi
2012 Ducati Monster 696 ABS with Termignoni system
PIGH8TER is offline
post #6 of 9 Old 11-13-2005, 10:19 AM
rejeep
I have the transmission lines from a V8 to a 46RE, interested?
rejeep is offline
post #7 of 9 Old 11-14-2005, 08:52 AM
gpJeep
Why can't you just cut out the hose from the steel line and put in new transmission rubber hose with the proper fittings on it to the rad from the steel line.
Had to do it on my intrepid and it worked , sure the line ain't so pretty lookin but then it worked
gpJeep is offline
post #8 of 9 Old 11-16-2005, 03:41 PM
94glide
This is what I did....
I cut out the rubber hose portion..got 3 flared fittings...a piece of steel brake line..or transmission line..and my flaring tool...done!!!or you may even be able to use compression fittings...I see no need for that type of set up...for years cars have had all steel lines that fit directly from the tranny to the radiator...or aux cooler...
just a suggestion...
94glide is offline
post #9 of 9 Old 11-16-2005, 04:24 PM
dodgetk81
I just got fuel lines from Classic Tube in NY for my Dodge Ram. I belive the connectors are the same for the fuel lines as they are for the trans lines. Give them a call and see if they will sell you the connectors or if they will make a hose to your specs. www.classictube.com
97 TJ 4.0, auto, 4.5" RE long arm, 33 " MT/R's on Moabs, 4.10's, 8.8 w/Aussie locker, A to Z rockers, A/A SYE, Warn M8000, Vanco
dodgetk81 is offline
1997 Grand Cherokee Transmission Jhagelberger ZJ Grand Cherokee Forum 11 12-29-2014 12:59 PM
'95 Grand Cherokee Transmission Problem kuppoppo ZJ Grand Cherokee Forum 5 09-06-2007 11:53 AM
97 grand cherokee transmission fhgjikb ZJ Grand Cherokee Forum 1 07-16-2006 03:29 PM
jeep grand cherokee transmission UncleTom ZJ Grand Cherokee Forum 7 01-21-2005 09:11 AM
99 Grand Cherokee transmission replacement. Steeda WJ Grand Cherokee Forum 2 12-17-2003 07:27 PM
