96 grand cherokee fuel pump woes - JeepForum.com
post #1 of 9 Old 09-09-2009, 10:32 AM Thread Starter
turbojeep88
hows it goin guys? my dad is having a problem with his jeep. he parked it at work and it was running fine but when he went to leave it just cranked and cranked. i went to check it out today and i couldn't hear the fuel pump and i noticed the gauges weren't cycling when i turned the key on. i think its the fuel pump but was wondering if the gauges not cycling pointed to something different like a bad ground or ecu or something? what do you guys think?
turbojeep88 is offline
post #2 of 9 Old 09-09-2009, 10:46 AM
cj7guy
That's hard to say man. Start checking the basics, fuel, spark compression.
If you have fuel and spark, do a compression test, my guess is that you'll find a problem with one of the first two.
07 JKU - 6spd - LSD rear
cj7guy is offline
post #3 of 9 Old 09-09-2009, 11:29 AM
rugermack
If you have fuel and spark, check ths CPS. Does the tac move when you crank the engine ?
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #4 of 9 Old 09-11-2009, 06:42 PM Thread Starter
turbojeep88
update: it has neither fuel nor spark and the guages wont cycle when switched to on. cranks over fine and all other things electrical seem to work. ran just fine the other day. any suggestions?
post #5 of 9 Old 09-12-2009, 02:13 PM
242forme
1977 CJ5
Have you checked the fuses in the Power Distribution Center?(the black rectangular box next to the battery)
A few years ago, my '96 Zj had the same problem you describe. I found one of the fuses blown. It was the fuse for the ASD (automatic shutdown relay) I replaced the fuse and it started right up. Then, when I put it in gear,it blew the same fuse again. On mine the wiring harness for the rear oxygen sensor had sagged down and was rubbing on the driveshaft. The wires were worn through creating a short.
242forme is offline
post #6 of 9 Old 09-15-2009, 10:58 PM Thread Starter
turbojeep88
yea that was the first thing i checked, i didnt notice any blown ones. im goin back to look at it tomorrow hopefully i can figure it out. i googled the problem and found it might be the ecu or the factory alarm system so i guess i'll check that stuff out.
post #7 of 9 Old 09-16-2009, 08:42 AM
CanadianZed-J
Originally Posted by turbojeep88 View Post
...factory alarm system...
The factory alarm does disable the fuel pump but that wouldn't explain no spark.
LC.
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
CanadianZed-J is offline
post #8 of 9 Old 09-16-2009, 09:03 AM
Coletrickle
Did you check for codes?
If a CPS fails, it'll let the engine continue running, but won't restart after you shut it down. Just another thing to check. Mine did the same thing as what you're describing and it was bad wires to the CPS.
93 Grand Wagoneer
5.5" Hybrid Lift/BDS CA's
231/skids/33" KM2's
Homegrown Bumper
Aussie
Coletrickle is offline
post #9 of 9 Old 09-16-2009, 09:44 AM Thread Starter
turbojeep88
i think i figured it out. i unplugged the wire to the cps and the gauges worked again. plugged it back in and no gauges. looks like im replacing the cps tomorrow
01 Grand Cherokee fuel pump replacement rkreger2 WJ Grand Cherokee Forum 18 03-16-2016 11:35 AM
5.9L Grand Cherokee Fuel Pump Issue bandanaboyz ZJ Grand Cherokee Forum 7 10-10-2009 03:54 PM
93 Grand cherokee fuel pump toms93grand ZJ Grand Cherokee Forum 7 12-30-2007 05:49 PM
06 Grand Cherokee fuel pump problems?? Busther WK Grand Cherokee & XK Commander Forum 0 12-13-2006 09:39 AM
96 Grand Cherokee fuel pump change carrolles ZJ Grand Cherokee Forum 4 12-14-2002 11:40 PM
