96 grand cherokee engine noise - JeepForum.com
post #1 of 9 Old 02-24-2002, 07:06 AM Thread Starter
JohnnyG
My father bought a 96 grand cherokee limited about 4 years ago. 4.0 I6 with 27,000 miles. When he bought it the engine was noisy. It has a loose "rattle" sound in the lower end. Now at 87,000 miles, the jeep sounds like a diesel truck. It has a very loud lower end rattle. There is NOT a knock, it has not spun a bearing, but it just sounds loose. He maintains the Jeep well. We do all the work our selves. Oil every 3000, just put on new break pads and shoes, front discs replaced under recall. The Jeep has an all new ehxahst system, including the Cat that was relpaced under recall.
Is this loose "rattle" sound a common problem? What should we do to fix this? main bearings, rod bearings, ect.?
My father has an 87 wrangler he bought about 7 years ago. we re-built the engine, put in a new tranny, t-case, all steering linkage, and more. he loves that Jeep, so he bought this Grand Gherokee. He likes the Cherokee, but wants to get rid of this engine noise.
We appreiciate any advice you can give us.
JohnnyG is offline
post #2 of 9 Old 02-24-2002, 10:47 PM
Neil
Sounds like pistom slap. Not unusual for the I-6. Wouldn't worry about it.
5.9 ZJ
98 ZJ 5.2
Neil is offline
post #3 of 9 Old 03-18-2002, 12:40 AM
PEEJ JZ
i've got a 96 zj 5.2 v8 and i'm getting the same thing like a rattle , you can here mine mainly at 2500rpm - 3000rpm , sometimes lower rpm, but mostly in that range , sometimes not at all, i put my jeep on the scanner and nothing came out of it , am still looking into it, will let you know if i find out anything, hope you do the same , thay did tell me it was the cat but i changed it and still same thing, my jeep has 193000km on it yes km i'm in canada.
if they test drive one they will understand
PEEJ JZ is offline
post #4 of 9 Old 05-03-2004, 01:46 PM
slaterny
I'm having a similar noise, it's driving me crazy...did you find anything else out about the noise?
1996 GRAND CHEROKEE LAREDO I6 BONE STOCK (SO FAR!)
1997 FORD EXPEDITION EB
slaterny is offline
post #5 of 9 Old 05-04-2004, 10:29 AM
cfkingfish
cfkingfish's Avatar
Is it internal or external? You may have some worn motor mounts - that wont come up on an OBD .
-Christian
Christian
89 XJ 4.0 AW4
K&N 6x9 cone filter setup
Converted to TJ axles - 5-297 U-joints
Optima Red Top
Custom exhaust
www.ishopfaulkner.com
cfkingfish is offline
post #6 of 9 Old 05-05-2004, 02:37 PM
Meerkat
The first thing I would check is the dust shield on the lower half front of the transmission bell housing. They are metal on metal and if the bolts get loose, they rattle like mad.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #7 of 9 Old 11-04-2007, 12:48 PM
tetatdo
1994 ZJ
I have this same problem that came up with my 4.0L after a tranny rebuilt. Above 3,000 rpm, I get this loud rattling noise (no vibrations). But in 4x4 mode, I get a VERY hard vibration at the same rpms.. any help? Is it the main bearings?
tetatdo is offline
post #8 of 9 Old 11-04-2007, 02:28 PM
tennesseewj
It seems to be a pretty common problem with very few answers. Ever heard anyone say a 4.0 will run as long as a diesel but be just as loud?
2004 4.0 Selec-Trac
BB->Black Diamonds->General Grabbers
Originally Posted by Sporer65 View Post
You need to learn, there are 3 things that all JF members must like beside Jeeps:
(1) Guns (2) Women (3) Bacon
Originally Posted by GraKee99 View Post
I was bored so I forded the river. No oxen were lost.
tennesseewj is offline
post #9 of 9 Old 11-04-2007, 03:32 PM
BLACKzj52
my friend has a 4.0 xj and he had a rattle.. turned out his exhaust manifold had a crack in it..
dunno if its the same thing, but it rattled alot
and i figured since its the same engine it might be ur issue.. not sure tho
BLACKzj52 is offline
Check Engine Light On: 1995 Jeep Grand Cherokee Limited 4x4 4.0 Engine Keith1975 ZJ Grand Cherokee Forum 7 11-04-2014 09:31 PM
1997 Grand Cherokee engine noise? donzi9769 ZJ Grand Cherokee Forum 8 01-01-2009 09:12 AM
Oil engine Castrol Edge is ok for Jeep Grand Cherokee WJ engine 3.1 VM Motori ? diogene ZJ Grand Cherokee Forum 0 11-11-2008 02:51 AM
07' Grand Cherokee noise after starting up Sloe Rootworker WK Grand Cherokee & XK Commander Forum 1 11-06-2008 12:03 PM
ZJ Grand cherokee Ltd noise... (s) slh542000 ZJ Grand Cherokee Forum 4 07-01-2004 09:30 AM
