Quantcast 96 door wont open from outside - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 96 door wont open from outside
Old 10-14-2008, 04:22 PM   #1
rocafella99
So about a week ago my friends driver side door handle stopped opening the door, but you can open it from the inside.. anyone have any clue what to look at or how expensive this could be?
rocafella99 is offline   Reply With Quote
Old 10-14-2008, 04:32 PM   #2
ISUzj
1994 ZJ
Child safety locks are only in the back I believe, esp not DS door: but does the button give at all when you press it, or does it just push down real easy?
Can't wait to get started, but my wallet can......
~~~_______oooo_
~~ / ../...\...\_____\
~~[_---_____---_\-\\\\\\-\
~~~(o) )-o---(o) )-o---) )
94ZJ 5.2 Red; Rusty's 3" Coils,Skyjacker hydro's, Brush Guard, Custom Rear Bumper, Custom Roof Rack, KVG Quick Discos, 31-10.50-15's DAYTON TIMBERLINE A/T OBA 2 Gallon tank
Can't buy it? BUILD IT!! Do it cheap too cuz your in college
My Build Thread Align your jeep yourself B N B#175
ISUzj is offline   Reply With Quote
Old 10-14-2008, 04:49 PM   #3
FPKites
ZJjazzyJim
FPKites's Avatar
Quite possible that the linkage came loose in there. Remove the door panel (3 screws and several body panel clips), then carefully peel back the vapor barrier - careful not to rip it, you need to put it back. When you look in the body of the door, you'll see what I'm talking about. They're basically steel rods that have a right angle and a plastic clip to retain them. The one going from the door handle to the latch may have come loose.
Jim Karlin
"Duh! Big RED Jeep!!!"
Best mod you'll ever do on ANY vehicle!!!!
FPKites is offline   Reply With Quote
Old 10-14-2008, 06:02 PM   #4
rocafella99
i just realizeed my moms boyfriend does own an auto body shop haha, im gonna let him know what it may be so its easy for em and i dont kill his time
Old 10-14-2008, 06:40 PM   #5
MDcherokee
stuck door
just had the same problem open the door pull the two small rubber grommets out of the door near the handle on the inside of the door and lube the linkage work the handle from the outside this solved my problem the pivot points were just a little rusty
MDcherokee is offline   Reply With Quote
Glock Forum
