96 Disk Drake Removal Problems (Help) - JeepForum.com
post #1 of 9 Old 08-21-2009, 07:03 PM Thread Starter
96jeepman
Hey Guys,
Searched the threads couldnt find any info on the ZJ's just WJ's. Workin on the rear breaks on my 96 limited ZJ inline 6. My parking brake has not been functionable and I think this is somehow not allowing me to remove the rear brake disk. How can I disingage/remove the park brake in order to remove rear disk. Any advice is much appreciated. Have tried hitting it with soft mallet no luck. Thanks
Rubicon express 4.5 inch lift. OME nitrous charger shocks. 15x8 craggar soft 8's and 32x11.5r15 bighorns . Elemtal Design Componets, amps and 10 inch subwoofer
96jeepman is offline
post #2 of 9 Old 08-21-2009, 07:05 PM
elmer_fud
there should be a star wheel that you can access from the axle side to release the parking brake shoes
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #3 of 9 Old 08-21-2009, 07:09 PM Thread Starter
96jeepman
Great. will i rotate that with a screwdriver?
post #4 of 9 Old 08-21-2009, 07:30 PM
elmer_fud
you should be able to
Brian
post #5 of 9 Old 08-22-2009, 10:11 AM Thread Starter
96jeepman
losening the star bolt seems to be losening parking brake, however it seems to be getting hard/almost impossible to turn the star bolt any further. The brake disk is still not able to come off. Do I try to continue to turn the star bolt? any ideas?
post #6 of 9 Old 08-22-2009, 12:30 PM Thread Starter
96jeepman
I have pb blasted and let sit for a couple of hours hit from behind with 4lb mallet getting nowhere. How long should I let it sit with the pb blaster? Ive losened the parking brake conection so theres slack, turn the star bolt to disengage parking brake from rotor, seems that there is no interference between parking brake and rotor so I think its just "welded" rusted in place. any Idea? thanks for the help
post #7 of 9 Old 08-22-2009, 01:19 PM
SJZ
Victim of Hope & Change
SJZ's Avatar
Location: . . . . . . . . . . . . . . . A shining city upon a hill
If you have not been able to budge the rotor from the beginning, it may be rusted to the hub, in which case you should try some heat (propane, MAPP, etc) on the rotor where it contacts the hub. You don't want to go too crazy (as in glowing red) as you run a risk of damaging a bearing or seal. As you apply the heat, hit the rotor with the mallet, first one side, then the other.
If the rotor is moving around already, chances are its hung up on the parking brake, in which case try to close down the star adjuster some more & keep moving it around, banging from behind.
Sometimes you have to be aggressive & realize that you may be buying a new rotor before you're through.
-Steve
"Those who hammer their guns into plows, will plow for those who do not." -Thomas Jefferson
___________________________________________
'98 ZJ Laredo 5.2 Selec-Trac (249 to 242 swap)
'05 KJ Limited 3.7 Selec-Trac
'94 ZJ Limited 5.2 Q-Trac- sold, after 17 years
'67 International Harvester Scout 800; 345ci V8,T18 4spd, Dana 20 TC
'06 Chrysler 300C SRT8 6.1L
SJZ is offline
post #8 of 9 Old 08-23-2009, 11:58 PM Thread Starter
96jeepman
thanks guys got the job done this was helpful. Just had to sack up and hit it
post #9 of 9 Old 08-24-2009, 12:48 AM
BRIANC500
adda boy
BRIANC500 is offline
REC Nav disk Eject thabet_2 WK Grand Cherokee & XK Commander Forum 5 01-08-2016 06:18 PM
radiator removal problems babgrip ZJ Grand Cherokee Forum 1 10-16-2008 09:15 AM
need new navigation disk piasa WK Grand Cherokee & XK Commander Forum 6 10-12-2008 03:55 PM
Ten disk CD changer carpetking ZJ Grand Cherokee Forum 12 09-25-2006 12:35 PM
Rear Rotor Removal / Emergency Brake problems wvresq ZJ Grand Cherokee Forum 4 09-10-2005 10:32 PM
