96-98 PCM repair procedure W/Pictures - Page 2 - JeepForum.com
 10Likes
post #16 of 215 Old 12-19-2011, 11:45 PM
GotMoose
1994 ZJ
Yea, it is likely a custom design for Jeep. Then they are bound by a contract not to tell anyone anything...
GotMoose is offline
post #17 of 215 Old 12-20-2011, 08:21 AM
ZeeJay1997
Originally Posted by JS97ZJ View Post
ZeeJay, How's your new ride?
My new ride is my old ride... still chugging along without a hitch. Sometime in 1Q12 I will probably swap the ZJ for something more practical and efficient.
ZeeJay1997 is offline
post #18 of 215 Old 12-20-2011, 10:05 AM Thread Starter
JS97ZJ
I could have used MeanGreen's OBD3 scanner when repairing your unit. It more than likely would have given me more insight as to what was dropping out after 3 days of operating normally.
Being able to re flash it would also taken out the possibility that the programming wasn't the final solution. After re-flowing you unit, it ran like a dream. I guess I'll just have to place yours in the WTF file? (blue screen anomalies)
Is the replacement PCM running without ty's? And one other question. The PCM I worked on...Can you disco the battery to reset it and go for another 3 days before it acts up again?
JS97ZJ is offline
post #19 of 215 Old 12-20-2011, 12:01 PM
ZeeJay1997
I had to tie one of them because some knucklehead broke the lock tabs off.
In regard to cut offs, it's really wierd. I think it has something to do with the volatile memory because once it starts cutting off (after 3 or so days), although the malfunction resets the monitor circuits to "not ready" (as does disconnecting the battery), the only way to make the malfunction go away, is to disconnect the battery. Go figure...
post #20 of 215 Old 12-20-2011, 05:59 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I've got two from california versions I think. I'm thinkiing about opening one of em. Thr second cardone I have has been doing fine. But you always have that creppy feeling. "Creppy" is my new word,lol, half of creepy and crappy.
coralman is offline
post #21 of 215 Old 12-20-2011, 09:21 PM Thread Starter
JS97ZJ
If we knew how long it takes for the PCM to finally settle in after the battery has been disconnected we might have the answer to your PCM's troubles. If it was a component break down I don't think it would take 3 days to show it's face.????
Software glitch?
JS97ZJ is offline
post #22 of 215 Old 12-20-2011, 09:36 PM
MeanGreenZJ
The PCM settles in after the battery has been disconnected when a drive-cycle has been completed.
Software glitch?
MeanGreenZJ is offline
post #23 of 215 Old 12-20-2011, 09:52 PM
Candymancan
MM i always wondered what they used to keep water out of the PCM, never relised it was encased in 2 inchs of gel on both sides lol
Candymancan is offline
post #24 of 215 Old 12-20-2011, 10:03 PM
ZeeJay1997
This is just a WAG (or something to discuss) based on fighting this thing for 3 years. I think the problem I'm seeing is a malfunction of the circuits or software that does this:
TRIP DEFINITION
The term “Trip” has different meanings depending
on what the circumstances are. If the MIL (Malfunction
Indicator Lamp) is OFF, a Trip is defined as
when the Oxygen Sensor Monitor and the Catalyst
Monitor have been completed in the same drive cycle.
When any Emission DTC is set, the MIL on the
dash is turned ON. When the MIL is ON, it takes 3
good trips to turn the MIL OFF. In this case, it
depends on what type of DTC is set to know what a
“Trip” is.
For the Fuel Monitor or Mis-Fire Monitor (continuous
monitor), the vehicle must be operated in the
“Similar Condition Window” for a specified amount of
time to be considered a Good Trip.
If a Non-Contiuous OBDII Monitor, such as:
Oxygen Sensor
Catalyst Monitor
Purge Flow Monitor
Leak Detection Pump Monitor (if equipped)
EGR Monitor (if equipped)
Oxygen Sensor Heater Monitor
fails twice in a row and turns ON the MIL, re-running
that monitor which previously failed, on the
next start-up and passing the monitor is considered
to be a Good Trip.
If any other Emission DTC is set (not an OBDII
Monitor), a Good Trip is considered to be when the
Oxygen Sensor Monitor and Catalyst Monitor have
been completed; or 2 Minutes of engine run time if
the Oxygen Sensor Monitor or Catalyst Monitor have
been stopped from running.
It can take up to 2 Failures in a row to turn on the
MIL. After the MIL is ON, it takes 3 Good Trips to
turn the MIL OFF. After the MIL is OFF, the PCM
will self-erase the DTC after 40 Warm-up cycles. A
Warm-up cycle is counted when the ECT (Engine
Coolant Temperature Sensor) has crossed 160F and
has risen by at least 40F since the engine has been
started.
This problem never occurs when the Catalyst monitor is not complete. Also it never has pending or active codes prior to or after failure.
post #25 of 215 Old 12-20-2011, 10:12 PM Thread Starter
JS97ZJ
I read an article somewhere that, on GM vehicles, the PCM's need to go through a series of different cycles of idle, acceleration, highway speeds, and slower speeds plus a few on and off cycles before the PCM is considered set to it's optimum proformance levels.
I worked on ZeeJay's unit, and thought that I had it repaired. When I received his, I installed it in my Jeep and it did what I expected it would do, shutting off until the ty-wraps were installed. I ran it for a couple of days and let it kick the hell out of me, then did the repair.
After I re-installed it back in my Jeep, it ran perfectly. If I would have kept it in my Jeep one more day I would have found the symptoms that Zee was getting. Gas gauge was dropping out (at first with no other symptoms) then a stumbling. It wouldn't show up for 3 days. If you reset the system by disconnecting the battery the 3 day cycle would start all over again.
Question here is why 3 days? What is considered a cycle or final cycle that our PCM's need to be finally optimized?
JS97ZJ is offline
post #26 of 215 Old 12-20-2011, 10:23 PM Thread Starter
JS97ZJ
Zee's gel was missing in his PCM. The ASD and 12v regulator chips had been replaced, and as you can see in some of the pictures, the back of his case was cut out and an abortion was performed.
JS97ZJ is offline
post #27 of 215 Old 12-20-2011, 10:28 PM
ZeeJay1997
Yeah, i did that...
post #28 of 215 Old 12-20-2011, 10:40 PM
MeanGreenZJ
Below is a PDF of the Chrysler drive cycle that lists the conditions that must be met before the PCM is ready with all monitors active after disconnecting the battery.
http://img.neons.org/archives/chrysler_drive_cycle.pdf
post #29 of 215 Old 12-20-2011, 10:56 PM
foxman97
Wow.... Thanks man I really appreciate you going out of your way to do this. Now i only need to find a jy that has and is willing to sell a PCM for my initial screw-up.
Originally Posted by BlackDaddyZJ View Post
in all of that i dont hear no, which by my logic and calculations actually means yes:2thumbsup:
foxman97 is offline
post #30 of 215 Old 12-20-2011, 11:03 PM
ZeeJay1997
Catalyst Monitor Drive Trace
Pre-Conditioning Requirements:
- MIL must be off.
- No DTCs present.
- Fuel level is between 15% and 85% full.
- ECT above 70 F.
- Engine must have run at least 90 seconds
- Engine between 1,350 & 1,900 rpm.
This is interesting because if the fuel is below about 1/4 tank when it fails, the fuel gauge pegs to zero. It also occurs only in the RPM range mentioned above.
So how does a catalyst monitor kill a PCM? (this is a rhetorical question)
CRD Oil Change Procedure rhusak WK Grand Cherokee & XK Commander Forum 5 08-28-2010 07:59 PM
procedure from 4hi to 4lo 69speed ZJ Grand Cherokee Forum 3 10-08-2007 09:33 PM
CAT Removal Procedure kdavis ZJ Grand Cherokee Forum 24 09-24-2007 06:51 AM
Connecticut Repair Shops Capable of Axle Repair? dogbait ZJ Grand Cherokee Forum 2 02-12-2007 06:28 PM
Cleaning procedure Endurancevm ZJ Grand Cherokee Forum 5 03-18-2006 05:08 PM
