'96-'98 to '93-'95 zj swap everything - JeepForum.com
post #1 of 10 Old 01-31-2014, 03:01 AM Thread Starter
paulwaller
hey guys,
I have a 96 zj limited right now that I just rolled and pretty much totalled the body everywhere. Everything runs perfectly though, fired up first try after sitting upside down for a day and drove it home. Thank god I know how to weld a stinger bumper up right.
I found a 94 limited with a blown tranny for $600 bucks that im picking up this morning.
My question is, is it possible to swap literally everything right down to the dash and door panels into the 94. Im not at all afraid of PITA jobs which I know this one probably is. I know the OBDI to OBDII is really the issue here, but is the actual bare bones body of the vehicle the same? The engine in the 94 is good according to the owner, but If I had to I wouldnt mind swapping in my motor if that was needed to make it compatible with the OBDII computer I would also have to swap in.
Man I sure would love to talk to ratmonkey right now....
paulwaller is offline
post #2 of 10 Old 01-31-2014, 03:39 AM
ZeeJay1997
Never heard of it, but I'm just guessing that minor differences in mounting will be encountered. As you said, you'll need to swap everything.
ZeeJay1997 is offline
post #3 of 10 Old 01-31-2014, 05:48 AM
Marcos
Every bit of wiring will need to be swapped
Marcos is online now
post #4 of 10 Old 01-31-2014, 06:32 AM
McCloudsZJ
Because RaceJeep
McCloudsZJ's Avatar
It has been done... But backwards of what you're doing. A dude OBD2'd a 1993 to run a OBD2 5.9 out of a 1998 LTD. It took him a little over a year to complete, but he did it. Everything down to the over head console and VIC was swapped.
In the garage: M1 4bbl
McCloudsZJ is offline
post #5 of 10 Old 01-31-2014, 07:43 PM Thread Starter
paulwaller
would I have to mess with the AC compressor and heater as well?
post #6 of 10 Old 01-31-2014, 08:44 PM
1998_ZJltd
that is the part that worries you ???
I would guess not unless you want to use the climate control from the newer .. If you are ok with the older ones system ... you shoud be able to tie in the heater in the engine bay and the ac may have a bracket issue ... but it may work .. not sure on the pulley size .. only issue may be the vacuumm controller but should be easy enough ....
1998_ZJltd is offline
post #7 of 10 Old 01-31-2014, 09:33 PM Thread Starter
paulwaller
haha Im just doing my research man. honestly my main objective is to have the 96+ interior. I just love the look of it. Really and truly though it's stupid to change the entire OBD system thorughout the engine, sensors, plugs, and wires just to feel a little more comfortable. I was just curious if it was possible but the cost sort of out weighs the benfit....
post #8 of 10 Old 01-31-2014, 09:34 PM Thread Starter
paulwaller
Thank you for all the replies though!
post #9 of 10 Old 01-31-2014, 09:51 PM
Mickey_D
Yeah, I would look at repairing the transmission on the 94 and call it good.
The only thing you might want to swap out is the transfer case if the 94 still has the 249. Also the 94 will have a D35 in the rear with drum brakes. Your F8.8 would be good to swap in.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #10 of 10 Old 02-01-2014, 08:21 AM
joey48442
I can't imagine anything would be insurmountable if everything was removed and swapped. If there are any differences I'm sure it's very minor. Maybe a few mounting brakets or wiring holes. I pulled everything (every last nut and bolt and wire) out of a 1992 Miata and installed it into a 1994 body and there actually is quite a difference between the years, although it doesn't look it. Engine is different, as well as wiring harness. I took my time and removed everything and transferred everything over. The harness was tricky to extract, but not impossible. It fired right up. Took my a winter of working a few evenings a week. I say do it!
Joey
joey48442 is offline
engine 5.2 , grand cherokee zj , interior , swap
