96' 4.0l 4x4 conversion - Page 2 - JeepForum.com
post #16 of 28 Old 08-07-2013, 07:15 PM
SchizophrenicMC
2016 JK Wrangler
Ah, 4x4 swaps. I'm helping a buddy with his Isuzu Rodeo, go from 2WD to 4WD. We've already picked the donor apart, all we need now is to get the 4wd tranny rebuilt and installed, and the rest should take a day or two. He might also be sourcing a manual t-case for it, since the current case is electric-assist.
Anyway, for a ZJ, get a parts Jeep, you'll need it. The procedure, as follows, based on my experience with drivetrain swapping:
Donor Disassembly:
1. Remove driveshafts
2. Remove transfer case
3. Remove transmission
4. Remove t-case lever, mounts, and bezel
5. Remove GDM/VIC if applicable
6. Remove rear axle*
7. Remove font axle*
8. Remove any desired parts
9. Remove Jeep
*Do this in tandem with your Jeep, for easier removal of the parts vehicle later. It's a lot easier to move around and work with a vehicle sitting on its axles, even if the axles are only partially attached. We did a switcharoo of Scott's trucks' rear axles in about 3 hours. Only bothered to put 2 bolts back onto the mounts for the donor truck because it only needed to be winched onto a flatbed.
Preparation:
1. Inspect and repair transmission and t-case
2. Clean axles and paint them for rust protection
3. Acquire brake fluid
Installation of 4x4 System:
1. Swap rear axle
2. Swap front axle
3. Be sure to connect brake lines appropriately
4. Swap transmissions
5. Install transfer case
6. Install t-case linkages and shifter
7. Install driveshafts
8. Add or change fluids wherever necessary. Count on a full transmission fluid fill.
9. Bleed brakes
10. Install GDM/VIC if applicable
11. Inspect installation, ensure everything works properly
12. Test drive
Things I'm not Sure About; Application-specific:
* The transmission crossmembers may be different between 2WD and 4WD
* Rear driveshafts are different, I think, but check first
* You may need to use the 4WD PCM. I know nothing about the 2WD PCM
* If you're using 3.73 axles from the parts Jeep, you'll need to use both its axles if your Jeep is 3.55
* I don't know if 2WD ZJs have the t-case linkage mounts. If they don't, you'll need the ones from the donor. Things like that are why you buy a whole donor vehicle.
Signature rules are dumb
SchizophrenicMC is offline
post #17 of 28 Old 08-07-2013, 07:36 PM Thread Starter
znm1994
The information ive got form several different forums shows it being pretty simple.
Parts I need,
Over drive section of a 4x4 transmission
Transfer case
Linkage
Front and rear drive shafts
And front axle.
The donor jeep I have is geared with 3.73s, which matches my gear ration on my 2x4 jeep. Donor is also a 96 4.0.(same as mine) Which from my understanding has the same transmission as mine. (42re) this means I shouldnt have a problem taking the OD section from my 2x4 jeep and bolting on the 4x4 OD section. This eliminates the need for an entirely new 4x4 transmission.
The PCMs for the zjs seem to be the same for all. For example mine went bad, instead of paying $200 for a new flashed one with my vin number, I went and pulled one out of the junk yard from a 97' zj. And its worked great.
Everything that I need seems to be there as far as brackets, just empty slots.
As long as this month of non stop research isnt wrong, I think ive got a pretty good understanding so far
I will keep the posting updated with changes
Jeeps are built not bought right!?
znm1994 is offline
post #18 of 28 Old 08-07-2013, 08:20 PM
SchizophrenicMC
2016 JK Wrangler
I believe you will need the entire 4x4 transmission as I believe the tailshafts are different. Also, I don't know about the 42RE, but the 4L30E from Scott's truck had an entirely different case design from the 4x4 version. I believe this may also be true of the 42RE.
If you're buying a whole donor, just go ahead and pull everything of value off. You won't be getting any of that money back when you scrap it, might as well sell parts you don't need, and it pays to be prepared if you do need the transmission et cetera.
post #19 of 28 Old 08-07-2013, 08:30 PM
dnuccio
why would you need the rear axle schizo? 2wd and 4x4 jeeps all got the same rear axle, dana 35 (unless it was a 96+ v8 with the 44a)
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #20 of 28 Old 08-07-2013, 08:37 PM Thread Starter
znm1994
Hang on let me find you the link I read. And im not getting the whole donor. Just the parts from it, Its sitting in a junk yard
znm1994 is offline
post #21 of 28 Old 08-07-2013, 08:38 PM Thread Starter
znm1994
http://mallcrawlin.com/forum/showthr...way!!!-writeup
Heres the link
znm1994 is offline
post #22 of 28 Old 08-07-2013, 10:21 PM
SchizophrenicMC
2016 JK Wrangler
Well follow the writeup if it's there.
post #23 of 28 Old 09-15-2013, 06:57 PM Thread Starter
znm1994
My conversion is complete!
Jeep runs great, all I need to do now is find out why my linkage wont shift the transfer case, I think im missing a bracket, and I need to get 2 more driveshaft bolts for the front driveshaft. Im getting that stuff tomorrow and then everything should be done.
znm1994 is offline
post #24 of 28 Old 09-15-2013, 07:48 PM
kg6mov
Hears the voices
kg6mov's Avatar
Might just swap to a novak cable shifter, shifts way better than stock anyway.
kg6mov is offline
post #25 of 28 Old 09-15-2013, 07:50 PM
ZeeJay1997
well, you better get to changing your jeep info!
can you give a rough guestimate on the cost and man hours?
ZeeJay1997 is offline
post #26 of 28 Old 09-15-2013, 07:56 PM Thread Starter
znm1994
Cost was roughly 750. 400 for t case and driveshafts and front axle, and 300 for transmission then I spent about 40 on fluids.
Man hours ha, well I didnt have a transmission jack, that would of saved me atleast 2 hours. But id say about a day and a half to swap the transmission hook up linkage driveshaft and all that, then 2 days for the front axle swap. Just because I went through and changed all the components. Ball joints tie rods ext.
Cant wait to get the last little things I need tomorrow and take it out this weekend!
znm1994 is offline
post #27 of 28 Old 09-15-2013, 07:56 PM Thread Starter
znm1994
Alright ill look into it thanks!
znm1994 is offline
post #28 of 28 Old 09-18-2013, 01:07 PM Thread Starter
znm1994
Front driveshaft in and fixed the linkage.. tested it and my jeep did awesome. I was pretty suprised at how stong this set up is. 4x4 conversion was a success
znm1994 is offline
