95GC Computer problem - JeepForum.com
post #1 of 4 Old 10-16-2004, 10:48 AM Thread Starter
davidmcg
I just changed the oil in my 95GC and I can't get that vehicle info computer to reset to 3500 miles. Everytime I go through the cycle and get it to 3500, when I hit the set button, it goes to zero. I have no problem selecting the proper language, just the miles. Anyone else have similar problem and/or solutions? The only other 2 problems I have experienced with this machine was a frozen idler pulley that broke the serpentine belt. The other problem is that occassionally the engine cuts out only when the engine is warmed up. Sometimes it will only happen a few times, other times it will go on for an hour or so, or until the check engine light comes on. After turning the engine off and letting it sit for an hour so and it is usually fine. That 5.2L engine just keeps on going.
davidmcg is offline
post #2 of 4 Old 10-16-2004, 07:14 PM
Dalmask
What you're doing is setting the interval it renotifies you. What you're TRYING to do is reset the miles already passed. To do this, have the ignition "On", then hold the select button momentarily and then hold the set button for at least two seconds. As far as the engine cutting out: I'd pull the codes and see if it gives you any insight on what's triggering the check engine light.
-Dal
Dalmask is offline
post #3 of 4 Old 10-16-2004, 08:18 PM
Valv
Hey that's a great hint !!! Thank you....
I had my onboard system goin off with Perform Service for a while and didn't know what to do.
I suggest this one to go in the Stickys
Valv is offline
post #4 of 4 Old 10-17-2004, 07:30 AM
Meerkat
Valv,
I am ashamed of you...
I entered the term miles to service in our wonderful search engine and found This Post that I had made back in January explaining how to do this very thing...
But, you are right, it would be a good item for the FAQ. I will take that for action.
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
need solution,info,95GC cv joint... beaker6971 ZJ Grand Cherokee Forum 2 06-30-2009 05:34 AM
95GC 4.0L - Muffler Compatibility Question sarnone ZJ Grand Cherokee Forum 2 12-12-2008 09:52 AM
95GC no power when cold Dans95ZJ ZJ Grand Cherokee Forum 9 11-28-2007 01:28 PM
Cure for pinging? 95GC with 5.2ltr JKot55 ZJ Grand Cherokee Forum 14 11-05-2007 10:46 AM
95gc ??? 67piglet ZJ Grand Cherokee Forum 8 07-20-2006 10:53 PM
