95 zj transmission problems, need help - JeepForum.com
post #1 of 4 Old 07-24-2011, 08:41 PM Thread Starter
Jerbear0612
My 95 zj limited is having tranny problems. It'll shift from first to second, but once in second it won't shift anymore. It just stays in second and up the rpm's go. Any of you guys familiar with this problem? I only payed $400 for it so a complete shop rebuild at 2000+ dollars is kinda my last option. If it does need rebuilding is it simple enough that me and some buddies could get it done in my driveway? Thanks guys
Jerbear0612 is offline
post #2 of 4 Old 07-25-2011, 07:41 AM Thread Starter
Jerbear0612
Bump... Anybody?
post #3 of 4 Old 07-25-2011, 04:47 PM
97zjdriver
i think there are sertin tools needed for the job. but ether a rebuild or a new trans. the transmissions aren't made to well from the factory.
97zjdriver is offline
post #4 of 4 Old 07-25-2011, 04:51 PM
WhiteOut
WhiteOut's Avatar
Check the fluid when its warm and on a level surface. It should be red and not smell burnt. If it is not in good condition you can drop the tranny pan, change the filter and re-fill the fluid (run 1-3 quarts of fluid through with the pan off first).
If none of that helps, then you can go have the more expensive diagnostic work done. Don't go to a chain place, I found the shop that the local PD uses for all their tranny work and went there.
WhiteOut is offline
96 transmission problems... joe116 ZJ Grand Cherokee Forum 4 02-06-2011 07:48 AM
New Transmission problems jeffp2152 ZJ Grand Cherokee Forum 0 04-11-2010 03:35 PM
Transmission Problems ASUndevil ZJ Grand Cherokee Forum 4 10-30-2009 01:59 PM
Possible transmission problems. Please help!! SPL Tech ZJ Grand Cherokee Forum 7 08-12-2006 06:29 PM
Transmission Problems JeepGuyRyan ZJ Grand Cherokee Forum 5 08-09-2002 08:45 PM
