95 zj sputters when reach normal running temp?? help - JeepForum.com
post #1 of 20 Old 08-10-2010, 11:14 PM Thread Starter
josh95zj
i have a 95 zj 4.0 and i replaced the crank sensor cause it was randomly shutting off and not long after that was fixed and running great again it started sputtering when it gets to normal run temp. it doesn't die just sputters bad. if i hammer down all the way it clears up till i let off the gas. i cleaned the throttle body and the iac. i dont wanna just throw random sensors at it when i dont know what it is. any ideas?? i need help please. thanks
josh95zj is offline
post #2 of 20 Old 08-11-2010, 08:25 AM
LordHobbit
Sounds like an o2 sensor to me. If you wish to replace it, give Kolak a pm.
93 red ZJ 190k 4.0. Spent more money than I should have ...
Isn't red the only color a vehicle should be?
If at first you don't succeed, use more speed.
LordHobbit is offline
post #3 of 20 Old 08-11-2010, 12:06 PM
phitmein
phitmein's Avatar
have you checked for any codes?
phitmein is offline
post #4 of 20 Old 08-11-2010, 06:12 PM Thread Starter
josh95zj
Yeah it's not throwing any codes except 12 battery disconnect last 50 starts.
josh95zj is offline
post #5 of 20 Old 08-11-2010, 10:08 PM
freakinheep89
my moneys on the O2 or the coil. mine didnt throw any codes when my O2 was bad, it takes alot for them to throw a code.
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #6 of 20 Old 08-11-2010, 11:28 PM
phitmein
phitmein's Avatar
also, check the wires going to the O2 senors, to see, if the plastic on the wires has been burnt or whatever and is shorting out ...
If I remember right, Ratmonkey found that on his ride once upon a time.
I do think that it would be throwing a code on that if so .
With luck, maybe the Rat will come out of the woodwork here and chime in ...
phitmein is offline
post #7 of 20 Old 08-11-2010, 11:38 PM
phitmein
phitmein's Avatar
Josh, I noticed you said this: "it started sputtering when it gets to normal run temp"
I have not slept well, for way too long, due to a death in the family.
But, if I remember right, isn't there something related to the cooling system, that does like a switch of the fuel ratio or something, as the motor warms up ???
Phit
phitmein is offline
post #8 of 20 Old 08-12-2010, 12:15 AM
alilredjeep
alilredjeep's Avatar
But, if I remember right, isn't there something relate to the cooling system, that does like a switch of the fuel ratio or something, as the motor warms up ???
Phit
I think you are speaking of the coolant temp sensor for the computer.Not the one for the guage. I used to think I was just getting watered down gas until I had that sensor replaced and then all was well.
Eddie
RED JEEP CLUB MEMBER #92
'92 WRANGLER, 2.5 Litre, 5 Speed, Rag Top, Superwinch LP8500, Cepek 130W Driving Lights, 31x10.50/AT with no lift, Of course! It rubs!
alilredjeep is offline
post #9 of 20 Old 08-12-2010, 12:23 AM
phitmein
phitmein's Avatar
Thanks, alilredjeep, that is just what I was trying to remember ...
Lack of sleep sucks.
Phit
phitmein is offline
post #10 of 20 Old 08-12-2010, 12:57 PM Thread Starter
josh95zj
I thought of the cts to but I went ahead and replaced the o2sensor to have it still doin the same thing. I think I'll try the cts cause it doesn't do it when it's cool.
josh95zj is offline
post #11 of 20 Old 08-12-2010, 04:42 PM
thecooptn
Hey all, not trying to jack this thread but I'm having the same issue today, my display is flashing bad coolant sensor and has for a while but I never had an issue till today, going to get it emission tested for new plates and it started sputtering when it got warm, it was also 103 degrees here today and I barely made it home. Where is the CTS for the computer and can you buy it at a auto parts store? Thanks COOP
thecooptn is offline
post #12 of 20 Old 08-12-2010, 07:59 PM
freakinheep89
the VIC display flashing coolant sensor bad is not the CTS, its actually the coolant level sensor in the coolant reservoir. check the connection to it and then replace if necessary.
TJ-
post #13 of 20 Old 08-12-2010, 08:50 PM
thecooptn
Thanks freakinheep, I've been reading all night and seen the thread about the flashing display so I now know it's not related now. Tomorrow morning I will be looking at O2 sensors and wiring and the coil. If ANYONE has any other suggestions please chime in. I have to get this to the emission station tomorrow and get it tagged due to it being the only vehicle I have running, KINDA!!!! LOL COOP
post #14 of 20 Old 08-12-2010, 11:23 PM
alilredjeep
Mine didnt do it when the engine was cool either but since I was driving it to work daily on the same route, I began to notice that it would began to stumble and skip for a few seconds (and then run good again) about the same place or about 4 miles into the trip and the temp guage was just beginning to show about half way warm by the guage.
I went through this for over a year, thinking it was bad gas and buying bottle after bottle of gas dryer to make it stop stumbling.
It finally got to the point it wasn't drivable and I couldn't figure it out.
It wouldn't throw any codes I could work with so I took it to a mechanic and he replaced the CPS and the CTS.
Haven't had any problems since but it did confuse an ASE certified mechanic for awhile.
Eddie
post #15 of 20 Old 08-12-2010, 11:31 PM
phitmein
phitmein's Avatar
Tell us more of what is going on, if you can, such as runs good until it gets hot ...
I think, what Freak was trying to tell you, was what that light was all about and a possible fix ...
He did not say, it's not your CTS, so don't rule that out ...
It can't hurt to check your coolant level too while you are at it.
phitmein is offline
4.0 , sputters , zj
Normal Operating Temp? eventer289 ZJ Grand Cherokee Forum 15 07-16-2013 12:02 PM
Lower than normal operating temp on a 5.2 ZJ - heating? dangaa ZJ Grand Cherokee Forum 7 01-10-2009 01:30 PM
normal temp z rated ZJ Grand Cherokee Forum 8 07-15-2007 07:06 AM
What's the Normal Operating Temp Range? Flyinbrick ZJ Grand Cherokee Forum 18 07-18-2006 12:11 PM
Normal Operating Temp on a 4.0 edfiero ZJ Grand Cherokee Forum 4 12-30-2004 01:36 PM
