95 ZJ Shutters when Flooring Gas - JeepForum.com
post #1 of 9 Old 10-09-2013, 09:22 AM Thread Starter
zwzj4life
I'm having a fairly new problem. When I floor the gas such as when merging with traffic or changing lanes the Jeep will get up to about 4k RPM and then starts "studdering". I'm not sure what else to call it. It wont accelerate any further and it feels like its skipping. It's very weird. If I accelerate without putting the gas all the way down maybe half to 3/4 of the way it's fine. It only does it when the gas pedal is fully engaged. What could possibly be the issue here. It's a 4.0 I6.
ZwZj4Life
1995 Jeep Grand Cherokee Laredo (ZJ) / 4.0L I6 / D30 front, D35 rear / 3 Inch Boost / 31X10.50R15 BFGoodrich M/T
Zombie Outbreak Response Unit #313
zwzj4life is offline
post #2 of 9 Old 10-09-2013, 09:29 AM
newfieZJ
Test the TPS for starters .
newfieZJ is offline
post #3 of 9 Old 10-09-2013, 09:35 AM Thread Starter
zwzj4life
Before I bought the Jeep the TPS was bad and the PO supposedly replaced it. If this one is bad also what could cause them to keep failing? If this is the case....
ZwZj4Life
post #4 of 9 Old 10-09-2013, 09:51 AM
PolkaPower
Cheap auto parts store sensors. They are very loosely calibrated to Mopars standards and often perform like crap right out of the box. Always use Mopar sensors.
If you have a Junkyard nearby you can go grab a dozen or so and test them out for spares. I always grab whatever sensors I can find at the yards. Some of those still have plenty of life left in them.
Or you can buy new and not worry about it.
PolkaPower is online now
post #5 of 9 Old 10-09-2013, 09:57 AM
zjosh93
I'd also take a look at your ignition and catalytic converter.
zjosh93 is offline
post #6 of 9 Old 10-13-2013, 04:18 PM
BeDifferent
this happened to me with 95 grand v8, found it to be a bad cat, but also muffler was bad, replaced both and problem gone. still could be tps or gas filter. (or more or combinations)
Jeep Grand Cherokee 1995 v8 5.2 205000
BeDifferent is offline
post #7 of 9 Old 10-13-2013, 05:43 PM
ZeeJay1997
if the engine temp rises a bit when it starts missing, you can bet it's the cat.
ZeeJay1997 is online now
post #8 of 9 Old 10-14-2013, 02:38 AM
youwish0411
1994 ZJ
I had this same exact problem.Thought it was the fuel filter, but it didn't fix it. Eventually it got worse to the point where it wouldn't start anymore... Sounds stupid simple but check the coil wire. That was the problem with mine... bad wire. Put a new wire on it and now it is back to running like a top. Just a suggestion. Good luck!
youwish0411 is offline
post #9 of 9 Old 10-14-2013, 06:19 AM
newfieZJ
Coil wire is a great lead . When was the last tune up ? This could be a bad plug even , might work , just not well .
Give us the low down on what you know as been done to this jeep .
BTW , a simple test for the ignition would be , hose it down and then try to start it . Any hiccups , and you found your problem . Good ignitions can handle a good engine bay cleaning without issue , I pressure wash mine all the time . Double check all the wires for good contact at the plug and distributor cap . Spark jump could very well be your issue . Simple fits
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
