95 ZJ Runs rough/Check engine light - JeepForum.com
post #1 of 6 Old 08-28-2008, 10:02 AM Thread Starter
txgpr
I have a 95 Laredo 4.0. I recently has it towed home with a dead fuel
pump and both 60A alt fuses blown. I made the repairs and got it
running again but... Now I get a check engine light and the following
trouble code 12 "Problem with Battery Connection: Direct input to
controller disconnected within the last 50 key ons" The jeep also runs
like crap. Can anyone tell me what the proble is or where to look
txgpr is offline
post #2 of 6 Old 08-28-2008, 06:04 PM
sadass
code 12 will stay until you have 50 start. or at least 50 key turns. no problem there. It happens after battery/power disconnect. I have also had to change my fuel filter after my pump went. Its on the driver side frame- Unibody rail in front of rear tire. take it off and dump gas out in a glass in reverse flow direction and see if there is alot of debris comes out, my second pump went because i did not seal the top of tank well and i found sand in it.
sadass is offline
post #3 of 6 Old 08-28-2008, 06:08 PM
Mickey_D
I agree. A grenading fuel pump can and will deposit all the broken pieces and debris from the pump mechanism into your fuel filter. It could also be that the fuel pump went out because it sucked a bunch of crap up from the bottom of the tank that was supposed to be filtered out by the sock...
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #4 of 6 Old 08-28-2008, 06:24 PM
-Joe-
-Joe-'s Avatar
code 12 should not cause a check engine light. It will be read but should not make it illuminate
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #5 of 6 Old 08-28-2008, 10:39 PM
sadass
if he checks the code however it will display a 12 and 55 (end of code) , you are also correct check light should not be on now.
sadass is offline
post #6 of 6 Old 08-28-2008, 10:54 PM
-Joe-
-Joe-'s Avatar
Thats what I meant.. It should not cause the light to come on.. Ill get a 12 then 55 if i check mine now.. Always have even though the battery has not been disconnected in some time.
I would recheck the codes if the light is still on.
Here they are if needed:
To display codes cycle the ingition key On-Off-On-Off-On within three seconds. Count the number of flashes, first digit, pause then second digit will be displayed in a series of flashes. (2 flashes, pause, 1 flash = 21)
11 - No Crank Reference Signal At PCM (Crankshaft Position Sensor)
12 - Battery Disconnected Within last 50 Key-on cycles
13 - No Change In MAP Sensor
14 - MAP Voltage Too Low Or Too High
15 - No Vehicle Speed Sensor Signal
17 - Engine Is Cold Too Long
21 - O2 Sensor Signal At Center Or Signal Shorted To Voltage
22 - ECT Sensor Voltage Too Low Or Too High (ECT = Engine Coolant Sensor)
23 - Charge Air Temperature Sensor Voltage Too High Or Low (Intake Air Temp Sensor)
24 - Throttle Position Sensor Voltage Too High Or Too Low
25 - Idle Air Control Motor Circuit Shorted
27 - Injector Control Circuit Signal Not Responding Correctly.
31 - EVAP Purge Solenoid Circuit Open Or Shorted
32 - EGR System Failure
33 - A/C Clutch Relay Circuit Open Or Shorted
34 - Speed Control Solenoid Ciruit Open Or Shorted (Vacuum Or Vent)
37 - Torque Converter Clutch Solenoid Circuit Open Or Shorted
41 - Generator Field Not Switching Properly
42 - Auto Shutdown Relay Control Circuit Open Or Shorted Or No ASD Voltage
44 - Battery Temp Sensor Voltage Out Of Limit
45 - Overdrive Solenoid Circuit Open Or Shorted
46 - Charging System Voltage Too High
47 - Charging SYstem Voltage Too Low
51 - O2 Sensor Signal Stays Below Center (Lean)
52 - O2 Sensor Signal Stays Above Center (Rich)
53 - Internal PCM Failure
54 - Sync Pick-Up Signal Not Detected (Camshaft Position Sensor/Ignition Pickup)
62 - PCM Failure SRI Miles Not Stored
63 - PCM Failure EEProm Write Denied
55 End Of Codes
- Joe -
-Joe- is offline
WJ Check engine light, rough running. Windowsrookie ZJ Grand Cherokee Forum 1 12-04-2009 11:21 PM
Transmission SLIPS!! Engine Runs Rough kelso1319 ZJ Grand Cherokee Forum 2 07-15-2009 05:14 PM
Rough Idle/check engine light on Cherokee0512 ZJ Grand Cherokee Forum 5 07-01-2009 04:52 PM
Engine runs rough michiganmaveric ZJ Grand Cherokee Forum 2 01-10-2008 06:33 AM
0 oil pressure and no check engine light? Also what trigers major check engine fault SPL Tech ZJ Grand Cherokee Forum 9 01-08-2007 07:28 AM
