95 ZJ - Rear Speaker Grills - HOW to remove?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 95 ZJ - Rear Speaker Grills - HOW to remove??
Smoking Deal on Jeep Slip Yoke Eliminator Kit with rear 13Rough Country Jeep Suspension Deals at Rockridge 4WD!Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREE
Unread 08-21-2005, 09:05 PM   #1
n4aof
Junior Member
This question is WAY below the level of most of the "technical" discussion here, but this seems the most appropriate place to ask...
I need to replace a bad speaker in the left rear door of by 95 Grand Cherokee with the fancy factory stereo system. I've got a pair of speakers that I think will fit, but I can't figure out how to get to the speakers.
The speaker grills don't have any visible external fasteners and seem like they ought to be able to "pop" off... when I've tried prying around the edge I can tell where they are fastened to the door, but either there is some trick to getting them off or they take a LOT more force than seems reasonable.
- Help??
n4aof is offline   Reply With Quote
Unread 08-21-2005, 09:45 PM   #2
rm1515
on my 96 you have to take off the whole door panel..
take out the screws and it comes right off...
rm1515 is offline   Reply With Quote
Unread 08-21-2005, 10:07 PM   #3
Guumba
The door panel will come off real easy when you remove the screws. Be careful popping the clips out though, they have a tendency to break if you force them too hard. Good luck!
1998 Jeep Grand Cherokee Limited
AKA "The Black Stallion"
120k on the clock.
Black inside and out.
5.2 Litres of gas guzzling power.
** TOTALED! UGH! **
Guumba is offline   Reply With Quote
Unread 08-22-2005, 04:11 AM   #4
n4aof
Junior Member
Thanks.
Unread 08-22-2005, 09:48 AM   #5
doyll
first remove the screw covers: one behind release handle (to unlatch door) and other is in armrest. Remove the screws. Now take a 1" wide X 1/8" thick flat prybar and pop all the plastic push-in fasteners loose from the door being careful not to break the door panel. Pull bottom of panel away from door a little and lift to unhook it from window and get it off the release handle. Now don't pull panel alway too far. You now have to unhook the electric controls from the panel.
Good Luck!
1997 ZJ 4.0, 42re, 242, 3.73, tow hooks, reciever hitch, skids, OBA, F>R lift, Rancho 9000s, Addco 1.25", JKS discos, 265/75r MTs on stock wheels, 99+ intake, Banks look-alike header, sliders,
NEED: adjustable upper front control arms, front track bar frame bracket for JKS/RE bar, adjustable rear track bar, Addco rear sway bar, winch
doyll is offline   Reply With Quote
Unread 08-22-2005, 03:18 PM   #6
n4aof
Junior Member
got it done
Thanks all
