95 ZJ fuel line removal & Oil filter removal - JeepForum.com
post #1 of 7 Old 10-12-2006, 10:14 PM Thread Starter
Ahardy4
Ok so I'm working on the ZJ I bought a couple of weeks ago, and I've run into two little hold ups. First I'm trying to disconnect the fuel line from the fuel rail, but it turns out that I'm supposed to have some magic little tool for this? Is there a way to get the fuel line off without the fuel line disconnect tool? Is this something I can find at Autozone (they're closed right now or I would check)? Also whoever put the last oil filter on either way over tightened it, or didn't lubricate the gasket because that sucker is not coming off . Any ideas on how to remove a seized oil filter? Thanks for the help guys.
EDIT: 1995 ZJ 4.0L 4WD
Ahardy4 is offline
post #2 of 7 Old 10-12-2006, 10:19 PM
-Joe-
-Joe-'s Avatar
You should be able to find the tool at a parts store. Why are you removing it?
Large screwdriver stuck thru it and turn. Messy but works
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #3 of 7 Old 10-12-2006, 10:42 PM
gomes512
1994 ZJ
just buy an oil filter wrench lol
Yep your magic wonder looks like:
http://www.amazon.com/FUEL-LINE-DISC...8&s=automotive
gomes512 is offline
post #4 of 7 Old 10-12-2006, 11:36 PM Thread Starter
Ahardy4
changing the head so I need to get the intake manifold off. I.E. taking off the fuel rail. Thanks for the help. I'll see if I can find an oil filter wrench, otherwise I'll look into large screw drivers
4.0L
4WD
Bone Stock
Ahardy4 is offline
post #5 of 7 Old 10-13-2006, 12:31 AM
-Joe-
-Joe-'s Avatar
No need to remove the rail.
Just unbolt the rail from the intake, unplug the electrical connectors on the injectors.
You can pull the injectors and rail out as one unit.
Entire rail will move out of the way so you can remove everything else.
Oil the o-rings just a bit, line them back up and pop them back in.
All with the fuel line still attached.
Done it several times now.
- Joe -
-Joe- is offline
post #6 of 7 Old 10-13-2006, 12:25 PM Thread Starter
Ahardy4
Cool I'll do that, thanks.
4.0L
4WD
Bone Stock
Ahardy4 is offline
post #7 of 7 Old 12-02-2007, 02:33 PM
matt2008
I used the cap to a Dennison "Marks A-Lot" marker. Cut the cap in half, take the half (without the closed end) and cut it in half length wise. Use tape on one side to keep halves together. Place over fuel rail pipe in front of connector. Push fuel line connector towards fuel rail while pushing tool towards connector, then pull off fuel line connector. Worked for me in just a few seconds.
matt2008 is offline
Oil Filter Adaptor Removal (my way) greasefingers ZJ Grand Cherokee Forum 137 11-08-2016 09:38 AM
Quick Question!! Back to the WJ 4.0L Fuel filter... Removal?? JonM81 ZJ Grand Cherokee Forum 0 05-01-2009 03:04 PM
WJ Rear Brake Line Splitter/Breather Removal doublejz ZJ Grand Cherokee Forum 2 04-03-2009 11:04 AM
3.0 v6 diesel oil filter cap removal tool Roughneck 6zero WK Grand Cherokee & XK Commander Forum 5 01-27-2009 05:07 AM
Leaking rear break line, fitting removal? ZJcrawler45 ZJ Grand Cherokee Forum 10 08-28-2008 01:58 PM
