Quantcast 95 zj 5.2 rear main seal - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 95 zj 5.2 rear main seal
Old 07-02-2007, 09:22 AM   #1
Orvisman
SandSurfer
Orvisman's Avatar
anyone have this work done, have a round about cost? mines a leaking not real bad but it does have a leak
any other work I should get done at the same time????
2004 Overland 4" KOR/IRO Long Arms
2004 Rubicon 6.5" RK X-Factor LA on 35" KM2s 488s Tom Woods & plenty of BTF Armor ORO U-Turn system
1995 Jeep Orvis 4.0 3" Rancho
www.jeeporvis.com ... www.jeepartist.com ... www.kmaoffroad.org Virginia Beach ... www.obxbreakers.comOff season Jeeper Deals
Orvisman is offline   Reply With Quote
Old 07-02-2007, 09:45 AM   #2
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Not sure how much it would cost. Lot of work. I'd replace the oil pump and clean the pickup tube screen while I was in there.
HighLonesome is offline   Reply With Quote
Old 07-02-2007, 12:53 PM   #3
SpooN-FeedeR
Probably a few hours by someone that knows what they are doing. I would guess around 3 bills+ if you paid someone to do it. It's not hard to do yourself if you have the time and tools.
You need to remove the starter, exhaust pipe, the pan, oil pump, then the bearing cap. Then put it all back together.
SpooN-FeedeR is offline   Reply With Quote
Old 07-02-2007, 03:24 PM   #4
Orvisman
SandSurfer
Orvisman's Avatar
only place around I know of is the stealership. if it were under 5 bills Id say I do it, the rest of the heep is in good condition.
still pondering ... The friend mechanic that I took it to said if it were him the thing is worth fixing, if I was gonna sell soon I could try one of the newer stop leak treatments..
I just want to build it up... oh the money
Old 07-02-2007, 09:52 PM   #5
Orvisman
SandSurfer
Orvisman's Avatar
btt
anyone pay for this service? how much?
thanks
Old 07-02-2007, 10:52 PM   #6
driabyor
1994 ZJ
K-D Tools KD 492 Oil-Seal Remover and Installer
The K-D Tools KD 492 is a Oil-Seal Remover and Installer. This oil seal remover and installer removes and installs upper rear main oil seals with engine and crank-shaft in place. It works on both wick and neoprene type seals.
94 Grand Cherokee ... 332,000 miles
5.2 liter 242 :)
Rancho 5000 steering stabilizer
driabyor is offline   Reply With Quote
Old 07-03-2007, 12:16 PM   #7
Orvisman
SandSurfer
Orvisman's Avatar
have you used that b4??
Old 07-04-2007, 02:02 PM   #8
driabyor
1994 ZJ
I haven't personally , but a mechanic friend uses one.. He said sometimes it's easy ,then sometimes it's not.
5.2 liter 242 :)
Old 07-04-2007, 02:03 PM   #9
driabyor
1994 ZJ
Oh! It's only about 35 bucks for the tool.
5.2 liter 242 :)
Old 07-04-2007, 07:42 PM   #10
Orvisman
SandSurfer
Orvisman's Avatar
thanks
Old 07-04-2007, 08:18 PM   #11
Upside
Have you guys seen this over at mallcrawlin?
http://www.mallcrawlin.com/forum/showthread.php?t=2881
I need to do this at some point but it seems like a can of worms on my 200K ZJ
Upside is offline   Reply With Quote
Old 07-04-2007, 10:01 PM   #12
Orvisman
SandSurfer
Orvisman's Avatar
thanks for that link, I would never attempt this myself, but that info will go along way when looking for the right price. I will ask for the oil pump too.
I really appreciate all the great advice!!!
I suppose Im looking at 500 bones. darn that will put off a bumper setup from KOR 4 awhile.
Old 07-05-2007, 09:26 AM   #13
HighLonesome
That is a great writeup by Aprilzwarrior. One thing he didn't mention is to prime the motor before you start it. Pull the coil wire off so she won't start. Then crank the motor until you get oil pressure. Now reconnect the coil and start the motor. It takes awhile, so you need a strong battery.
Old 07-05-2007, 09:36 AM   #14
sand zj
Mine has leaked since I put the motor in. The dumb engine wont die and that is what it will take for me to replace the seal. I would rather spend the money in other ways but that is just me. Throw some cardboard on the garage floor and get the new bumper!
Dan
[B]If you don't get stuck, keep trying![/B]
'96 ZJ 7" LA, 318, 231, 8.8 (welded), d30 (LockRight), 4.10's, 33x13.5x16 TSL's, no interior...
sand zj is offline   Reply With Quote
Old 07-05-2007, 10:36 PM   #15
BradMB2004
amen to that brotha!!
i just tell myself that my oil pan leak prevents everything underneath from rusting
Brad
2004 Wrangler X
2001 Grand Cherokee Ltd.
1997 Grand Cherokee Ltd.
BradMB2004 is offline   Reply With Quote
Glock Forum
