95 ZJ - 4 inch RC lift- drive shaft issue - JeepForum.com
post #1 of 7 Old 04-08-2010, 03:17 PM Thread Starter
WaffelNinja
1987 YJ Wrangler
I have a 95 zj with a 4 inch RC lift. I installed the left my self. Today I hit a bump and the front drive shaft broke where it connects to the axle. I drove it slowly to a shop in town and the guys says that because of the lift that my drive shaft is to short. So it pulled out.
He says I need a driveshaft spacer that makes the shaft longer? I can't find one on the Internet so I don't know if it's a real thing or not. He can't find one so he might have to get a shop to make one.
Is this a common problem? What are other solutions? Shouldn't RC have told me needed a longer shaft or something? Why only the front and not the back?
WaffelNinja is offline
post #2 of 7 Old 04-08-2010, 03:24 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
Your back could very well be on the verge of coming out.
However, I don't think that is what happened in the front. It broke at the joint, and didn't actually pull apart correct?
If that is the case, was the joint a CV joint (rubber booted at the joint) or a U-joint (like a "plus" sign")?
If it was a CV joint, the angle of the lift just wore it out. Typical problem.
Either way if you can upgrade to a DC (Double-Cardan) drive shaft in the front (that is one where the transfercase has a Double-Cardan joint at the axle end has a u-joint) of proper length you'll be better off then any hokey spacer. If you go with my above recommendation then you'll also need to make sure you have u-joint yokes are both ends (transfercase and differential).
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #3 of 7 Old 04-08-2010, 03:27 PM Thread Starter
WaffelNinja
1987 YJ Wrangler
The joint had the rubber boot thing on it so its a CV.
post #4 of 7 Old 04-08-2010, 03:30 PM Thread Starter
WaffelNinja
1987 YJ Wrangler
would i have to replace the front axle if i wanted to upgrade to a Double-Cardan shaft?
post #5 of 7 Old 04-08-2010, 03:43 PM
ArloGuthroJeep
Mr. Hyde!
No, just the yoke on the differential (both sides depending on what is at the transfer case end). The TC end is an easy swap. The differential is more difficult. The yoke is on there snug (think 200+ ft-lbs of force) and is holding a crush-sleeve under the proper tension. When you replace the yoke, you ideally want to put that crush sleeve under the same tension. Not doing so puts the bearings and gears at risk for premature failure. They make adapter plates that go from the CV style flange to a u-joint yoke...that is the easiest if you don't want to risk it or spend money to have someone else do it.
post #6 of 7 Old 04-08-2010, 04:41 PM Thread Starter
WaffelNinja
1987 YJ Wrangler
What would be the cheepest fix
post #7 of 7 Old 07-12-2010, 04:15 PM
newkid92
so what all should be replaced? i am getting this lift i believe but im not sure what all needs to be done as far as a new drive shaft and sye and things like that. any help would be great
newkid92 is offline
Front Drive Shaft Problem with lift kit KDXFreestyle200 ZJ Grand Cherokee Forum 3 09-12-2009 08:28 PM
6 inch lift on wj. weird issue redwjjeep ZJ Grand Cherokee Forum 46 10-22-2008 06:19 PM
New drive shaft with lift soccerfreak3377 ZJ Grand Cherokee Forum 9 03-31-2008 11:12 PM
Clunking Noise Possible Drive Shaft issue?? JEEPCD ZJ Grand Cherokee Forum 4 11-15-2007 02:50 PM
What Kind of Front Drive Shaft/Lift Kit ? Bosshound ZJ Grand Cherokee Forum 7 02-14-2005 11:43 PM
