95 tranny freshening up - JeepForum.com
post #1 of 7 Old 06-17-2013, 11:23 AM Thread Starter
yamazinger
1993 XJ Cherokee
got a 95 with the 5.2 auto. its got about 230xxx on it so its certainly nearing the end of its life, but i have had a problem for a while with the motor. I changed the cap, rotor, plug wires and plugs and it happened either right before or after i changed them. i cant remember. but anyway the motor hesitates when i drive it calmly. if i give it a reasonable amount of gas the motor runs great and no problems. it hesitates and bucks when i keep it at a steady highway speed and right before the tranny shifts. it acts like it starts to run very lean like the 02 sensor or something is reading wrong and telling the motor to run lean. i ended up changing the plug wires like 2 or 3 times and nothing changed. checked everything as well as firing order of plug wires- all good. what would cause hesitation and bucking at steady highway speeds and right before the tranny shifts? it makes it terrible to drive any kind of distance and no one offered any good advice a year ago when i asked this same question. does it sound like a tranny issue or motor? i know it seems like the motor but im just not familiar with trannys enough to rule that out. thanks
yamazinger is offline
post #2 of 7 Old 06-17-2013, 03:46 PM
4x4andmetal
That definitely could be an o2 sensors. If you replace them, make sure to get the mopar ones.
1996 4.0 Laredo. Weekend warrior
1999 Pontiac Grand prix GTP. Daily driver
1995 318 laredo. Gone
4x4andmetal is offline
post #3 of 7 Old 06-17-2013, 04:06 PM
dellis
2005 WK
When you accelerate, the computer will suspend the readings from the O2 sensor specifically to give you power with a richer mix. Then, when you let off of the gas and cruise, you will once more be using the information from the O2 sensor to regulate the air/fuel mixture.
So, yes, the O2 sensor could be your problem.
A quick way to diagnose is to disconnect your upstream O2 sensor and drive. It will throw a code but the computer will be using default values. If you notice that the problem disappears, then replace your O2 sensor. If not, then look elsewhere.
dellis is offline
post #4 of 7 Old 06-17-2013, 04:17 PM
PolkaPower
Only one O2 on the 93-95's. Get a Mopar or NTK sensor.
PolkaPower is online now
post #5 of 7 Old 06-18-2013, 05:09 AM Thread Starter
yamazinger
1993 XJ Cherokee
whats the deal with using off brand o2 sensors? i was looking at bosch. i dont foresee this jeep running many more years here so im just trying to get the issue resolved cheaply. and buying a dealer part is never cheap
post #6 of 7 Old 06-18-2013, 06:58 AM
PolkaPower
The aftermarket O2 sensors are more universal and not ZJ specific which can cause them to act like they are bad right out of the box.
Some info here http://www.jeepforum.com/forum/f13/o...506-a-1321465/
post #7 of 7 Old 06-18-2013, 01:08 PM
eagsc7
1994 ZJ
The thing to remember about ALL Jeeps is that even the Worst maintainer can keep these things going for over 500,000 Miles. Course, at that point your replacing the Drivers seat for Padding issues and realize that the floor under it has rusted out. This is from personal experience in Missouri where MODOT puts Salt on the roads. When it DOES rust out on you, get some plate steel and weld it on. Don't know how to weld? Watch some youtube vids and go for it! You can't screw too much up with a vehicle this old anyways.
Off to the JY for some more parts!
eagsc7 is offline
