95 not engaging 4 lo.. selector lever has not tug - JeepForum.com
post #1 of 4 Old 10-15-2013, 12:27 AM Thread Starter
dereksmith667
I haven't checked my linkages yet, but I am curious is a 249 tc vacuum operated? I just noticed the problem today.. I am hoping it is a linkage, and not a bad line.. I do notice a vaccum line to my front diff. So unfortunately I'm assuming it is vaccum operated.. I notice the line keeps popping out, can I get that fitting somewhere?I may have answered my question, but I am asking for some experienced advice lol!
dereksmith667 is offline
post #2 of 4 Old 10-15-2013, 01:36 AM
98GCLimited
All ZJ transfer cases are mechanically shifted no vacuum operation. The tube on your front axle is the diff breather tube to vent any pressure from building up in the axle.
Check your shift linkage, the torque shaft bushing is a common failure and it wont shift properly if its not in place. In the pic below you can see the body side bushing has fallen out of place on the torque shaft part of the transfer case shift linkage. Also check to make sure there are little green bushings in all 4 of the connections where the shift linkage meet the tabs all located under the Jeep, one on the bottom of the transfer case shifter, two tabs on the torque shaft and one on the shift tab on the transfer case should all have little green bushings in them too.
98GCLimited is offline
post #3 of 4 Old 10-15-2013, 05:12 AM
newfieZJ
Put a small hose clamp on the hose off the front diff , readjust where it clips on the side of the factory air box to give it some slack . Adjust/inspect linkage as said .
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #4 of 4 Old 10-15-2013, 08:58 AM
JohnnyZJ
x2 he explained it well. i would have just said 'check the linkage'
07' JKUR rollin on 35s
JohnnyZJ is offline
