95 LMTD Disable factory alarm? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 95 LMTD Disable factory alarm?
RuffStuff Memorial Day Sale!Rugged Ridge Modular XHD Snorkel Now for both 3.8L and 3.6Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-13-2004, 11:37 PM   #1
matz445
Hello, my drivers side door sets off my alarm and I do not have a keyless remote. I was told there is a fuse you can pull to disable the factory alarm. This sucks because it will not let me start the vehicle. I do not need the alarm so please anyone if you could tell me what I can do that would be great. Because I'm stranded at the moment. Thanks
matz445 is offline   Reply With Quote
Unread 04-14-2004, 04:55 PM   #2
1st95gc
There are three fuses that control the alarm, #6,7 and 21 they are all blue 15 amps. When you open the passenger door they are on the side by the glove box. Just try pulling #6 and see if that does the trick. As far as I know it does not effect anything else. I'm still trying to get mine to work. Let me know what happens.
1st95gc is offline   Reply With Quote
Unread 04-15-2004, 08:05 AM   #3
matz445
kinda solved
well I ended up disconnecting all the sensors, was the only way I could get the thing to start. I don't need the alarm anyway as It is my work beater for pulling so it's no big deal to me. At least it runs now woohoo...
Unread 04-16-2004, 11:43 PM   #4
GrandRubicon155
i have a 93' GC laredo and i can't use my power locks because it sets the alarm off. i've been tryin to disconnect the alarm for 2 years but the dealership told me that there was no way to disconnect it, if you pull fuse #6 do the power locks still work? man i hope i can get this thing disconnected, thanks guys
sean
99' TJ Sport, 31inch MTR's, Lift Comming Soon
GrandRubicon155 is offline   Reply With Quote
Unread 04-18-2004, 04:06 PM   #5
Aen
Sounds like a rewire, I had a remote start and new security system put into my 95 GC. I was tired of it, period. I got something more reliable and now if I lock the truck from inside using the switch it arms the old security.
I have to use the trunk method to disarm it if I do.
I have been really lazy about trying to disable it, I am sure you can with some time.
Nothing is impossible
Aen is offline   Reply With Quote
