95 jgc fuel pump - JeepForum.com
post #1 of 5 Old 05-03-2013, 07:29 AM Thread Starter
daddyrich1959
95 jgc fuel pump
i have a 1995 jeep grand cherokee se 4.0 6cyl, problem started few months back. was running fine untill i poured a bottle of injector cleaner into the gas tank. week later i tried to pas another vechickle and my jeep was bunking like it was'nt getting enough gas. so slowly pressing the gas pedal i could build up speed, but if i mashed pedel to get faster speed it would start bunking like it was'nt just getting the gas. so i bought a fuel filter. when i took loose the fuel line from the tank side from the filter it looked like muddie water comming out, real dirty fuel. so after replacing the filter, it ran good for about 3 days. then i replaced the filter again. and the same thing with the dirty fuel.its been 8 months and 4 fuel filters. its still bunking like its not getting the right amount of fuel. i think the problem started when i poured the injector cleaner into the tank loosened up whatever was in the tank , and it started going through the fuel pump and filter. my question to you do you think i need to take down the fuel tank clean it out and replace the fuel pump and filter? i have already bought a new fuel pump and injectors. please give me your opinion on this. thank you.
daddyrich1959 is offline
post #2 of 5 Old 05-03-2013, 02:44 PM
79chiefs
1988 XJ Cherokee
But yes drop the tank, and see what is in there, by the sound of it, it REALLY needs to be cleaned. Replace fuel filter, and the sock on the end of the fuel pump, IF the pump is running correctly, it may need to be replaced as well.
99WJ Laredo I6-A 2wd
88XJ-Building on a budget.
95 E34 540i-DD
79chiefs is offline
post #3 of 5 Old 05-04-2013, 06:59 AM
79chiefs
1988 XJ Cherokee
Could a MOD please move this to the correct forum for the op please.
95 E34 540i-DD
79chiefs is offline
post #4 of 5 Old 05-10-2013, 07:28 AM Thread Starter
daddyrich1959
95 jgc fuel pump
Could a mod please move this to the correct forum. Thanks.
post #5 of 5 Old 05-13-2013, 11:13 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
I moved your thread to the ZJ Grand Cherokee section of the forum. I think these guys are your sister-ship peers.
***Chris***
chris87xj is offline
