Quantcast 95 grand cherokee wont start help! - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > 95 grand cherokee wont start help!
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 06-18-2007, 11:09 AM   #1
mrbigglesworth
Ok i have quite the problem. The main bearings went on my 95 V8 grand cherokee and I had to change out the motor. I bought a re-built motor from advance auto and put all the old manifolds/sensors/accesories onto the new block and head. Went to turn the key...no start. I have checked spark, timing, and fuel. All of which were o.k. The jeep will start and putt for about two seconds and then die. Also another thing I am sceptical about is the fact that the tachometer doesnt work. When the engine does run for a few seconds the tach just bounces, and I have replaced the crank shaft position sensor during the motor installation because it broke. I was thinking that the cps also runs the tach, and possibply this sensor could be bad or not working properly?? Any info would be greatly appreciated.
?[]|||||||[] Black 1990 YJ 4.2L 6cyl 5spd []|||||||[]
BLACK JEEP CLUB #1000
Mods:
3.5" Rough Country Lift Kit
2 inch shackle lift
JKS Telescoping front track bar
33"x13.5" Super Swampers with 15" x10" AR Wheels
Front and Rear Auto Lockers
SYE and CV shaft in rear
Motorcraft Carb Conversion
Imperial Electric Cooling Fan
Grill Guard Front Bumper
Hella Bumper Lights
Rear Towing Crossmember and Hitch
Diamond Plate Running Boards
CB Radio
mrbigglesworth is offline   Reply With Quote
Glock Forum
