95 Grand Cherokee - Strong Gas Smell!!
| TJ 5.25" Speaker Adapters - NalinMFG | Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed |
#1 | |
My wife's ZJ has started giving off a strong gas smell in the interior (no jokes!). It's worse if she just gets off of the highway, but it doesn't seem to be noticeable outside. Is there a common problem I should be looking for? I heard there's a recall for this but looked it up and there is no TSB. Scary stuff as my wife and our two year are in this vehicle...trying to not to drive it unless needed. Thanks.
#2 |
I would look at the fuel lines in the engine bay. It could be sucking the fumes in to the vehicle thru the heater. Gas cap on tight !!! The rear hatch ,is the seal in good shape. Mine had a small gap in the bottom the hatch,it would fill with dust as a drove down dirt roads. fixed it with good ole duck tape......
94 Grand Cherokee ... 332,000 miles 5.2 liter 242 :) Rancho 5000 steering stabilizer |
#3 |
I'd say check out the charcoal canister and hoses behind the front bumper on the drivers side.
97 ZJ 5.9L 242/4.5" RE Coils/1.75" Spacers/Claytons/JKS Control arms out back/Addco's/RE brake lines/35"TSL SSR's on 5.9rims/Currie steering/K&N/JKS rear trackbar/Claytons Front Drop tracbar/Dropped pitman/Bilstein 5125's/JKS BPE/JKS loop conversion/JKS Sliders/ZJilla rear bumper/Clayton front winch bumper/durango steering box/warn 9000i/Hambek Customs carbon fiber cowl hood #2of16/D30lockrite D44a |
#4 |
X2 on the charcoal canister & hoses.
'93 Limited, '96 Laredo (daughter's) |
#5 |
Also check that the injectors are not weeping. Obviously the leak is under the hood. The HVAC pulls fresh intake the air from under the windshield wipers.
Cheers Steve Trained Professional Crack-pot Go RU & WVU Football Teams 94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new 03 4Runner V8 (my wife's car) 94 Volvo 850 (my 16-yr old daughter's car) Five cylinder 88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new |
#6 |
O
So, if my gas smell is coming from the area of the canister, what needs to be fixed on the Canister?
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green 1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end 1999 Mazda Miata MX5 - Jet Black 1990 Jeep Cherokee Sport I6 - 4.0 litre White ~Junked~ |
#7 |
either there is a hole in it or one of the hoses is off or torn.
#8 | |
O
Harry
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
