95 Grand Cherokee Stalling Problem - JeepForum.com
post #1 of 11 Old 09-01-2008, 08:49 AM Thread Starter
hondajeep
I have a 95 Grand Cherokee Limited V8 5.2 with 115K miles. Most recently, the car started to "buck" and then stall after running for ~30 minutes. Sometimes she will start right up and other times I'll have to wait 5-10 minutes before she'll start again. She may run "clean" for a few weeks before the problem re-occurs. The check engine light flashes (never solid) as she is about to stall. I had the timing done, belts, plugs and wires changed along with the fuel injectors cleaned. Use 87 Octane and never let gas fall below 1/4 tank level. Want to get some other ideas before I go for a Fuel Pump. I'll never know when this problem will occur?.
Thanks for your help
Bob
hondajeep is offline
post #2 of 11 Old 09-14-2008, 04:18 PM
BliZZard911
I just went through 3 months of troubles ending up with the wiring to the fuel pump being bad. The wires were black and rusted inside the insulation (I presume water leaked in through the harness plug). I could drive the JEEP for short drives but it would die often and sometimes was either difficult to start or would not start at all. The power circuit for the fuel pump tested fine for continuity but would not carry a consistent 12v to run the pump. I re-wired the power and ground, now all is fine.
2000 Jeep TJ Wrangler - 4.0L, 5 speed standard - BONE STOCK FOR NOW
BliZZard911 is offline
post #3 of 11 Old 09-14-2008, 04:38 PM
-Joe-
-Joe-'s Avatar
Quick free test.. See if any codes were stored..
To display codes cycle the ingition key On-Off-On-Off-On within three seconds. Count the number of flashes, first digit, pause then second digit will be displayed in a series of flashes. (2 flashes, pause, 1 flash = 21)
11 - No Crank Reference Signal At PCM (Crankshaft Position Sensor)
12 - Battery Disconnected Within last 50 Key-on cycles
13 - No Change In MAP Sensor
14 - MAP Voltage Too Low Or Too High
15 - No Vehicle Speed Sensor Signal
17 - Engine Is Cold Too Long
21 - O2 Sensor Signal At Center Or Signal Shorted To Voltage
22 - ECT Sensor Voltage Too Low Or Too High (ECT = Engine Coolant Sensor)
23 - Charge Air Temperature Sensor Voltage Too High Or Low (Intake Air Temp Sensor)
24 - Throttle Position Sensor Voltage Too High Or Too Low
25 - Idle Air Control Motor Circuit Shorted
27 - Injector Control Circuit Signal Not Responding Correctly.
31 - EVAP Purge Solenoid Circuit Open Or Shorted
32 - EGR System Failure
33 - A/C Clutch Relay Circuit Open Or Shorted
34 - Speed Control Solenoid Ciruit Open Or Shorted (Vacuum Or Vent)
37 - Torque Converter Clutch Solenoid Circuit Open Or Shorted
41 - Generator Field Not Switching Properly
42 - Auto Shutdown Relay Control Circuit Open Or Shorted Or No ASD Voltage
44 - Battery Temp Sensor Voltage Out Of Limit
45 - Overdrive Solenoid Circuit Open Or Shorted
46 - Charging System Voltage Too High
47 - Charging SYstem Voltage Too Low
51 - O2 Sensor Signal Stays Below Center (Lean)
52 - O2 Sensor Signal Stays Above Center (Rich)
53 - Internal PCM Failure
54 - Sync Pick-Up Signal Not Detected (Camshaft Position Sensor/Ignition Pickup)
62 - PCM Failure SRI Miles Not Stored
63 - PCM Failure EEProm Write Denied
55 End Of Codes
bad fuel pump wont store any codes so you will need to pursue other diag measures..
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #4 of 11 Old 09-15-2008, 02:53 PM
donster
Stalling Grand Cherokee
Bob, Did you get your stalling problem resolved? I have same problem.
Thanks
Don
donster is offline
post #5 of 11 Old 01-16-2012, 05:13 PM
AAA
If your Jeep is having stalling issues, it is up to you to make the NHTSA (National Highway Traffic Safety Administration) issue a recall for the year and VIN numbers for the vehicles with this problem. They issued a recall for certain 1996 Jeeps with this exact same stalling issue. Please either call them or visit the website and enter your info and stalling symptoms. Let's make Jeep fix what they need to.
Either call the NHTSA at 888-327-4236 from 8am-8pm M-F Eastern time, or go to www.NHTSA.gov and click on the right side where it says, "Report a vehicle or child seat defect".
You can also click on this link which takes you directly to the page to file a safety complaint. https://www-odi.nhtsa.dot.gov/ivoq/index.cfm
It does no good to complain unless we let them know about it. Enter a formal complaint about what your vehicle is doing and make them pay for the repairs.
AAA is offline
post #6 of 11 Old 01-16-2012, 06:37 PM
badbird17x
badbird17x's Avatar
1994 ZJ
I understand what your saying, but how will any company make it if we expect them to warranty a 17 year old vehicle?
94 jz, bruiser, la, cage,5.3 ls, 36 swampers 98 jz, the mutt, 3.5 iro, 33 swampers, avalanche conversion, 02 north face avalanche blacked out work truck, 06 rhino R1 engine, 4x4, Leeroy's custom paint, 04 escalade wifes truck 22s, 03 duramax 18s, completely blacked out, efilive by nick, wicked wicked truck, 39 chop chevy rod, aluminum 5.3 ls, 08 apex, 310hp mcx turbo, holz 162, completely black, CCM built.
badbird17x is offline
post #7 of 11 Old 01-16-2012, 09:19 PM
sebian
X2
If we were talking about 0-5 year old vehicles, sure I would understand that. But criminie, these are 15-19 year old vehicles. Things are bound to fail (I call it normal wear and tear), and there will be common failures. But to make a recall out of it, is just a little over board...just imho of course. Though, if it was a major safety related recall, I would understand that as well.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
post #8 of 11 Old 01-17-2012, 02:57 AM
93zjbums
why are we dragging up 3 yr old threadsssssssssssssssssssss
93 zj laredo 4.0 with k & n intake 2 inch bb skyjacker shocks and 31 bfg at
92 chevy cheyenne 4x4 w/t with 32in procomps "The Beast" 184k
92 honda accord ex
92 xj stock 358k miles wifes
93zjbums is offline
post #9 of 11 Old 01-17-2012, 06:59 AM
sebian
Cuz someone was selling an agendaaaaaaaaaaaaaaaaaaaaaaa
sebian is offline
post #10 of 11 Old 04-16-2012, 11:48 AM
boatman1
stalling
grand cherokee stalling intermittently:
back off one turn the 2 torx screws on the computer cover, under the wiring plugs.[ECB on pass side firewall in engine compartment.]
screws are TOO LONG hitting something inside n short it!!!!!!
also solves key off battery drain(slow n slight}!!!!!!!
saw this on another forum....solved my problems!!!!!!!
boatman1 is offline
post #11 of 11 Old 04-16-2012, 12:13 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
That's enough unless you want a vacation.
Joe Dillard is online now
2000 Grand Cherokee Stalling problem garyo WJ Grand Cherokee Forum 6 04-17-2016 02:40 PM
99 Grand Cherokee Stalling Problem pigoo ZJ Grand Cherokee Forum 16 07-09-2015 11:16 AM
99 Grand Cherokee stalling Cirus ZJ Grand Cherokee Forum 4 04-16-2012 12:09 PM
96 grand cherokee stalling dirt machine ZJ Grand Cherokee Forum 2 09-15-2007 07:30 PM
Stalling Grand Cherokee Hammerhead ZJ Grand Cherokee Forum 2 12-06-2001 10:50 PM
