95 grand cherokee limited 4.0l re42 no 2nd or over drive - JeepForum.com
post #1 of 5 Old 04-27-2012, 11:24 PM Thread Starter
mflintstone
Picked this jeep up for $500 last weekend. Fixed fuel leak bad supply line off of tank. And hatch wouldn't open. Broken headlight fixed that to.
The transmission. Won't up shift. I can put it into 1st and 2nd stays in 1st. drive overdrive starts out in 3rd. And won't up shift to od. No codes all fuses good and relays all new.
Started to pull transmission tonight. What a choir. Well took pan off. few metal flakes in it. No magnet.
Got to looking around and pulled the accumulator cover off and. Found broken spring.
Got me doubting should I finish pulling the transmission?
What does the accumulater do?
The fluid didn't smell. Look good and not discolored.
What say all of you guys?
I've been reading here awile and finally have something to post.thanks
mflintstone is offline
post #2 of 5 Old 06-12-2012, 02:14 PM Thread Starter
mflintstone
Anyone think of anything else I should replace while I got her gut opened up?
post #3 of 5 Old 06-12-2012, 02:14 PM Thread Starter
mflintstone
I took her on to tranny shop today and they hooked it and wouldn't you know it problem with the governor pressure solenoid. Code was thrown for it. Cascade transmission has a kit for 199.88.
Replacing the 3 pin with a 4 pin and had solenoid and sensor, lock up and od solenoid with harness, output speed sensor, governor housing gasket,3-4 accumulator spring, filter and pan gasket. Good deal I think. Shop was trying to talk me into buying a remanufactured transmission for only $1600., lol just gotta laugh.
post #4 of 5 Old 06-13-2012, 07:16 PM Thread Starter
mflintstone
Got the stuff changed and yeah got 1st and over drive and boo codes wheeehooo
post #5 of 5 Old 07-21-2012, 08:39 PM Thread Starter
mflintstone
Crap now my dang transfer case is leaking.
