95 Grand CHerokee - JeepForum.com
post #1 of 6 Old 11-12-2013, 07:06 AM Thread Starter
Ernesto007
95 Grand CHerokee
95 Grand Cherokee starts and idles fine but dies if i put it in gear any gear Please Help
Ernesto007 is offline
post #2 of 6 Old 11-21-2013, 10:57 AM
ryanfuscozj
Could be a timing issue
ryanfuscozj is offline
post #3 of 6 Old 11-21-2013, 01:42 PM
pmillz09
1994 ZJ
I just had that problem. Clean the iac. Wen it does and u fire it back up does the check engine come on?
pmillz09 is offline
post #4 of 6 Old 11-21-2013, 02:09 PM
bigbill888
Check torque converter clutch solenoid. I don't know how to do it, but
google it.
96 ZJ Laredo, 4.0, 242, 230K
95 ZJ Limited, 4.0, 242, 140K
98 XJ Sport, 4.0, 231, 140K
All work well
bigbill888 is offline
post #5 of 6 Old 11-21-2013, 02:38 PM
ryanfuscozj
That happened on my brothers cummins, different because it's a diesel and his was due to poorly positioned governor springs
post #6 of 6 Old 11-21-2013, 03:19 PM
JasonStebbins
Check the transmission fluid while running warm in neutral. When is the last time you changed the filter? Any engine light codes? Could be the Governor Pressure Sensor/Solenoid, but start with the basics first.
Poop
JasonStebbins is offline
