95 grand 5.2 trans ?surging? - JeepForum.com
post #1 of 27 Old 10-08-2013, 04:55 PM Thread Starter
BeDifferent
95 grand cherokee 8, 5.2L 4x4, new tune up, new fuel filter, regular injector clean additives, all new front end ties, breaks,
Auto trans oil and filter done about 1300 miles ago, adjust TV cable yesterday = that put an end to the random “clunking” during shift, and made the shifting way smooth.
Issue: at about 65+ mph under acceleration, feels like surging, as if gas is restricted, but RPMs stay steady, and acceleration from 0 or any other speed is strong. “Surging” like pumping the gas pedal, and steady rpms make me think transmission adjustment.
? Tighten bands
? Replace adjusting .. solenoid… ? Is there anything to replace during a filter change besides the filter and oil?
Everything I know about the automatic trans is; pull pan, make mess, change filter, add oil. Check oil level.
Jeep Grand Cherokee 1995 v8 5.2 205000
BeDifferent is offline
post #2 of 27 Old 10-09-2013, 04:42 AM Thread Starter
BeDifferent
so I have been looking through the service manuel and answered part of my question, but I am not familiar with the automatic trans.
would it be just the band at 3rd/overdrive, or something else?
then I thought; some of these many sensors might be having some kind of effect on the shifting, Can a sensor cause 'pulsing' in the drivetrain?
post #3 of 27 Old 10-12-2013, 04:00 PM Thread Starter
BeDifferent
"surging" what exactly do you mean by that?
rapid go/ release/ go/ release/ go/ feeling,
check the fluid level lately? yes, running in neutral is full.
what could it be? I don't know, thats why I am asking ......
post #4 of 27 Old 10-13-2013, 12:16 AM
ozzy_2_me
1994 ZJ
you could try to adjust the throttle cable that goes from the throttle body to the transmission. are you shure it is the trans. hows the motor running?
ozzy_2_me is offline
post #5 of 27 Old 10-13-2013, 01:09 AM
sergio
I have the same problem In mine. Same year and engine. I've changed a lot of stuff on it and nothing. But trust me I know what you mean. It's annoying as hell. I hardly even drive it now cus of that. If you fix it please let me know!
sergio is offline
post #6 of 27 Old 10-13-2013, 11:42 AM
Jeeples
Jeeples's Avatar
I had the same issue shortly after installing new plugs, wires, cap and rotor.
Routing the wires described in the TSB below fixed it:
http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by wjjeep19 View Post
It is what Jeeples has *PARTIALLY* stated.
Jeeples is offline
post #7 of 27 Old 10-13-2013, 02:44 PM
sergio
Originally Posted by Jeeples
I had the same issue shortly after installing new plugs, wires, cap and rotor. Routing the wires described in the TSB below fixed it: http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Did this really fix it???
sergio is offline
post #8 of 27 Old 10-13-2013, 09:52 PM
throwinwrenches
Check the tps sensor on throttle body . They can cause surging and shift issues.
Don't worry you will break it.
throwinwrenches is offline
post #9 of 27 Old 10-13-2013, 10:26 PM
Jeeples
Jeeples's Avatar
No. I just thought I'd **** with ya.
Yes it fixed the random misfire CEL and surging at speeds above 45 MPH, which was most noticeable on the freeway for me.
Jeeples is offline
post #10 of 27 Old 10-16-2013, 05:42 AM Thread Starter
BeDifferent
that is the "TV cable", making that adjustment does help a wide range of issues.
post #11 of 27 Old 10-16-2013, 05:47 AM Thread Starter
BeDifferent
Did you also check or change out the TPS? and or make sure the plug wires are not touching anywhere?
I have not checked my TPS yet, (working on a s-10 starter issue taking too much time)
THis issue only just began, aka; tune up and new cat/muffler and test drive = all acceleration was good, then a few days later it began the "surging" ....
post #12 of 27 Old 10-16-2013, 10:27 PM
sergio
Originally Posted by BeDifferent
Did you also check or change out the TPS? and or make sure the plug wires are not touching anywhere? I have not checked my TPS yet, (working on a s-10 starter issue taking too much time) THis issue only just began, aka; tune up and new cat/muffler and test drive = all acceleration was good, then a few days later it began the "surging" ....
I actually changed the TPS because it died on me but the plug wires are everywhere didn't think it would cause this problem.
sergio is offline
post #13 of 27 Old 10-16-2013, 10:55 PM
sergio
I changed the TPS because it died on me but the wires are everywhere I didn't think that would be the cause.
sergio is offline
post #14 of 27 Old 10-23-2013, 08:03 PM Thread Starter
BeDifferent
changed out the TPS, made no change. accelerate from 0 to 60 is all good. cruising at 50 to 65 and then accelerate - automatic trans- feels like it is slipping and or jumping between gears... adjust a band?
or where to find details on how to analyze and adjust trans...
post #15 of 27 Old 10-30-2013, 10:16 PM
sergio
changed out the TPS, made no change. accelerate from 0 to 60 is all good. cruising at 50 to 65 and then accelerate - automatic trans- feels like it is slipping and or jumping between gears... adjust a band? or where to find details on how to analyze and adjust trans...
Anything work?
sergio is offline
