95 Grand 5.2 starting problem - JeepForum.com
post #1 of 3 Old 02-21-2010, 11:42 AM Thread Starter
bj420
hey guys hope you can help. i have a 95 grand cherokee with a 5.2L under the hood. i ran into a starting issue with at work. it started but the starter stayed engaged so i turned it off and on and nothing. it has done this twice before but started right up the second time i turn it over. now i have power from the battery to the starter. i tried to start in neutral but nothing. finally i put the ignition into the run possession and jumped the solenoid terminals and it started right up with no problems. i have no clue as to what to check or fix. the relay under the hood seems to be working for the starter relay. any help will be appreciated.
bj420 is offline
post #2 of 3 Old 02-21-2010, 03:29 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Sounds like corroded battery terminals and/or a bad battery.
HighLonesome is offline
post #3 of 3 Old 02-21-2010, 05:11 PM Thread Starter
bj420
thanks i'll give it a shot
bj420 is offline
1995 , grand cherokee , start problems
08 Grand Cherokee starting problems 08GCjeep WK Grand Cherokee & XK Commander Forum 13 12-29-2009 10:50 PM
97 Grand C (ZJ) 5.2 Starting Problem MNRed97 ZJ Grand Cherokee Forum 0 06-09-2009 09:04 AM
1993 grand wagoneer/grand cherokee, alarm problem help! greenday1425 ZJ Grand Cherokee Forum 3 03-03-2007 11:16 AM
96 grand starting problem DeJeep ZJ Grand Cherokee Forum 6 06-05-2006 09:24 PM
94 grand cherokee not starting just_get_pierce ZJ Grand Cherokee Forum 1 12-20-2005 06:23 PM
