'95 GC won't shut off - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > '95 GC won't shut off
WIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ Rancho rockGEAR promotion gear from January 1-February 29,
Unread 10-10-2013, 07:34 AM   #1
jbutrip
bought this Jeep w/problems, still trying to get it running. I knew it overheated when I got it, but it developed a new problem--turn the key to off, the engine keeps running. It won't shut off even if I disconnect the negative battery cable. I have to pull the fuel pump relay to get it to shut of. I have bench-tested the fuel pump and ASD relays, and they are working properly.
jbutrip is offline   Reply With Quote Quick reply to this message
Unread 10-10-2013, 12:09 PM   #2
zander21510
Dang...sounds like a diesel problem lol. I don't know how combustion can continue without a spark...there's no way it could get hot enough in there to cause combustion...could it?
[CENTER][URL="http://www.jeepforum.com/forum/f197/breckenridge-redemption-build-thread-3111777/#post29271881"]Build Thread: "The Jeep" 1995 ZJ Laredo I6 212k. 20 years 1 family.[/URL]
The New DD: 2015 Dodge Charger SXT Rallye[/CENTER]
zander21510 is offline   Reply With Quote Quick reply to this message
Unread 10-10-2013, 04:46 PM   #3
jbutrip
No, it isn't dieseling, the injectors & ignition are still working. Some of the warning lights will stay on, too--the ones that come on when the key is "On" before you start it.
Unread 10-10-2013, 04:50 PM   #4
zander21510
Even when you disconnect the negative battery cable? Have you tried disconnecting the injector wires?
Unread 10-10-2013, 05:26 PM   #5
chetzar
1994 ZJ
Disconnecting the Neg Battery Terminal wouldn't shut the engine off because once the engine is running all electronics run off the Alternator primarily, battery secondary. So as long as your alternator is good, the engine could run itself without having a battery connected.
chetzar is offline   Reply With Quote Quick reply to this message
Unread 10-10-2013, 05:51 PM   #6
jbutrip
Yeah, I decided that all disconnecting the battery cable did was prove my alternator was working.
Unread 10-10-2013, 05:57 PM   #7
xcaliber81
1994 ZJ
Yes hes right.
xcaliber81 is offline   Reply With Quote Quick reply to this message
Unread 10-10-2013, 07:15 PM   #8
zj97ltd
Is there a switch somewhere in the column that could have gone bad or shorted?
zj97ltd is offline   Reply With Quote Quick reply to this message
Unread 10-10-2013, 07:21 PM   #9
xcaliber81
1994 ZJ
Maybe the ignition is bad?
Unread 10-10-2013, 08:40 PM   #10
chetzar
1994 ZJ
It sounds like a bad ignition switch. My logic: the opposite of occurs when the lock cylinder goes bad (where you turn the key over and it does not spring back or kick over the starter, however all electronics kick on).
Unread 10-10-2013, 09:31 PM   #11
xcaliber81
1994 ZJ
Someone said to me the ignition is not replaceable and the entire column would have to be swapped out is that true?
Unread 10-10-2013, 09:47 PM   #12
chetzar
1994 ZJ
To my knowledge it is replaceable. I have replaced the ignition switch on my fathers 1994 Dodge Ram twice and the setup is almost exactly the same on the Grand Cherokee (it may even be the same part number)
Ignition Switch from AA: http://shop.advanceautoparts.com/web...gnition+switch
You should have to remove the Steering Column Cover, remove the lock cylinder, then remove the Ignition Switch. A special torx bit is required (with a hole in the center of the bit) to remove some of the screws for the Lock cylinder.
Unread 10-11-2013, 11:49 AM   #13
zjosh93
Replaced the one in my 93 with no problems.
zjosh93 is offline   Reply With Quote Quick reply to this message
Unread 10-11-2013, 11:53 AM   #14
xcaliber81
1994 ZJ
Well I guess my previous boss got taken for a ride then lmao.
Unread 10-17-2013, 06:04 PM   #15
jbutrip
I thought the switch fixed it, until I tilted the steering wheel all the way toward the dash. That's the real issue, but I don't know what's going on inside. Pinched wires? something messed up with the steering lock?
