'95 GC won't shut off - JeepForum.com
post #1 of 16 Old 10-10-2013, 06:34 AM Thread Starter
jbutrip
bought this Jeep w/problems, still trying to get it running. I knew it overheated when I got it, but it developed a new problem--turn the key to off, the engine keeps running. It won't shut off even if I disconnect the negative battery cable. I have to pull the fuel pump relay to get it to shut of. I have bench-tested the fuel pump and ASD relays, and they are working properly.
jbutrip is offline
post #2 of 16 Old 10-10-2013, 11:09 AM
zander21510
Dang...sounds like a diesel problem lol. I don't know how combustion can continue without a spark...there's no way it could get hot enough in there to cause combustion...could it?
zander21510 is offline
post #3 of 16 Old 10-10-2013, 03:46 PM Thread Starter
jbutrip
No, it isn't dieseling, the injectors & ignition are still working. Some of the warning lights will stay on, too--the ones that come on when the key is "On" before you start it.
jbutrip is offline
post #4 of 16 Old 10-10-2013, 03:50 PM
zander21510
Even when you disconnect the negative battery cable? Have you tried disconnecting the injector wires?
post #5 of 16 Old 10-10-2013, 04:26 PM
chetzar
1994 ZJ
Disconnecting the Neg Battery Terminal wouldn't shut the engine off because once the engine is running all electronics run off the Alternator primarily, battery secondary. So as long as your alternator is good, the engine could run itself without having a battery connected.
chetzar is offline
post #6 of 16 Old 10-10-2013, 04:51 PM Thread Starter
jbutrip
Yeah, I decided that all disconnecting the battery cable did was prove my alternator was working.
jbutrip is offline
post #7 of 16 Old 10-10-2013, 04:57 PM
xcaliber81
Yes hes right.
xcaliber81 is online now
post #8 of 16 Old 10-10-2013, 06:15 PM
zj97ltd
Is there a switch somewhere in the column that could have gone bad or shorted?
zj97ltd is offline
post #9 of 16 Old 10-10-2013, 06:21 PM
xcaliber81
Maybe the ignition is bad?
post #10 of 16 Old 10-10-2013, 07:40 PM
chetzar
1994 ZJ
It sounds like a bad ignition switch. My logic: the opposite of occurs when the lock cylinder goes bad (where you turn the key over and it does not spring back or kick over the starter, however all electronics kick on).
chetzar is offline
post #11 of 16 Old 10-10-2013, 08:31 PM
xcaliber81
Someone said to me the ignition is not replaceable and the entire column would have to be swapped out is that true?
post #12 of 16 Old 10-10-2013, 08:47 PM
chetzar
1994 ZJ
To my knowledge it is replaceable. I have replaced the ignition switch on my fathers 1994 Dodge Ram twice and the setup is almost exactly the same on the Grand Cherokee (it may even be the same part number)
Ignition Switch from AA: http://shop.advanceautoparts.com/web...gnition+switch
You should have to remove the Steering Column Cover, remove the lock cylinder, then remove the Ignition Switch. A special torx bit is required (with a hole in the center of the bit) to remove some of the screws for the Lock cylinder.
chetzar is offline
post #13 of 16 Old 10-11-2013, 10:49 AM
zjosh93
Replaced the one in my 93 with no problems.
zjosh93 is offline
post #14 of 16 Old 10-11-2013, 10:53 AM
xcaliber81
Well I guess my previous boss got taken for a ride then lmao.
post #15 of 16 Old 10-17-2013, 05:04 PM Thread Starter
jbutrip
I thought the switch fixed it, until I tilted the steering wheel all the way toward the dash. That's the real issue, but I don't know what's going on inside. Pinched wires? something messed up with the steering lock?
jbutrip is offline
