95 gc trans relay issue - JeepForum.com
post #1 of 17 Old 03-24-2013, 10:12 PM Thread Starter
chooching
Ok ive been searching hi and low for the right info with no luck. Ive come here to see if i can get some info..
alright im out cruzing my 1995 gc with a fresh trans rebuild not to long ago with maybe 100kms on it, all of a sudden it stays stuck in first gear and now it refuses to shift any of the other higher gears, iv e been researching and it could be the governor pressure switch or the ASD and ETAX relays/ trans relay,
this is where my dilemma has began for me.... for the life of me i haven't been able to find the trans relay aka: ASD and ETAX relays in my jeep in the engine bay in the fuse box it doesn't say any of these terms, did i miss something or does my gc not have this relay?
ive posed pics of my fuse box, i really hope some one can point it out please...
chooching is offline
post #2 of 17 Old 03-24-2013, 10:13 PM Thread Starter
chooching
post #3 of 17 Old 03-25-2013, 12:11 AM Thread Starter
chooching
or any info in general why my trans is not shifting out of first gear? would a speed sensor possibly cause this? any tips or tricks please.... cheers in advance for any help
post #4 of 17 Old 03-25-2013, 01:48 AM Thread Starter
chooching
well this just got interesting, i just took out the gc for a midnight scoot to see if anything changed and now its shifting the gears but defiantly seems to sometimes start in first then goes through 2nd then 3rd and od. but at a stop it seems to be in second when starting off some times not all the time, this seems more and more like the governor pressure switch/solenoid ?? from what ive been reading up this type of issue is very common with auto jeeps...
lifted 95 ZJ, fresh 318 v8, sitting on 33s
post #5 of 17 Old 03-25-2013, 01:58 AM Thread Starter
chooching
oh and heres my "green bastard" has new 318 v8 cost a grip load to build that motor, purrs and has tons of balls! rebuilt trans that needs some fine tuning lol, running 33s,
post #6 of 17 Old 03-25-2013, 03:58 AM
KoreaZJ
1994 ZJ
No Tranny Control Relay in 93-95... only 96+
Check for fault codes.
Learn how... HERE
KoreaZJ is offline
post #7 of 17 Old 03-25-2013, 04:33 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
You have a 46rh transmission. It's fully hydraulic controlled in first through third. If it's not shifting, it's a mechanical issue and I'd head right back to the guy who rebuilt it.
ratmonkey is offline
post #8 of 17 Old 03-25-2013, 01:48 PM Thread Starter
chooching
well its shifting now, but seems to pick and choose weather is going to use first to start off, is it possible its the governor pressure solenoid? theres no codes showing...
post #9 of 17 Old 03-25-2013, 01:54 PM Thread Starter
chooching
edit sorry
post #10 of 17 Old 03-25-2013, 02:07 PM Thread Starter
chooching
cant return as it was rebuilt before i owned it and the man that rebuilt it was an old timer in his 70s and now has passed away... so im on my own. ive seen all the new internal parts put in but i suspect that the governor is pooched...
post #11 of 17 Old 03-25-2013, 03:59 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
there is NO governor solenoid and sensor in your transmission. it's a mechanical pump.
post #12 of 17 Old 03-26-2013, 10:44 PM Thread Starter
chooching
thats interesting as the transmission shop are saying this, quote:
"no it has a gov pressure solenoid
the regular Cherokee doesn't , but all the Grand Cherkee's do
easy way to confirm for yourself - on the connector of te case harness
is it black with an 8 pin connector
I ma quite confident in my statement though"
your thoughts on this?
post #13 of 17 Old 03-26-2013, 10:58 PM
xcaliber81
Wow that red is very hard to see lol. Where in bc do you live. Try bringing it in to various transmission shops and see if they remember it. Or the old guy who passed away was he married at all did he live with anyone who would remember where the trans was rebuilt?
xcaliber81 is offline
post #14 of 17 Old 03-26-2013, 11:05 PM
KoreaZJ
1994 ZJ
You have a 46rh transmission. It's fully hydraulic controlled in first through third. If it's not shifting, it's a mechanical issue...
No governor solenoid on the 93-95 v8 grand Cherokee as the transmission is the 46rh with hydraulically controlled 1-3 shifts and electronically controlled 4th and torque converter lock up.
Find a different tranny shop. :
KoreaZJ is offline
post #15 of 17 Old 03-26-2013, 11:57 PM Thread Starter
chooching
are you saying theres no gov ????
